(#4)
(#5)
(#6)
| Member Posts: 51 Join Date: Feb 2010 | Check out a shareware program called BatteryCare It might not be able to fix your battery, but in my case it gave a percentage of how much it had deteriorated from maximum charge. Once you start using it, it also counts the charge cycles and lets you know when you should let it completely run down (every 30 cycles). It also gives you a better battery meter than the standard one. |
PS It's working fine now, except the battery won't recharge and the light keeps flashing red.
