KwisatzHaderach KwisatzHaderach is offline
Default External Sound Card - 01-20-2009, 12:15 PM
Has anyone tried using an external sound card and speaker setup on their mini? Since I plan on taking mine to work to listen to music while I work, would it be a worthwhile investment to buy something like an external Sound Blaster card and set of speakers for listening to music while I am there?
MSI P45 Platinum
Intel Q6600 @ 3.6ghz
Thermalright 120 Extreme
BFG 8800GT OC
Accelero S1V2
Creative X-Fi Xtreme Gamer
4GB Crucial DDR2 800
Antec Nine Hundred
Vista 64 Ultimate
LG Flatron W2452T
Dell Mini 9 16gb SSD 1GB memory 1.3mp Web Cam
Default Re: External Sound Card - 01-20-2009, 06:38 PM
Speakers? Do you work alone?
I would suggest trying a decent set of amplified speakers with the built-in sound first. Unless you're looking for concert-hall realism, it may be more than sufficient.
Default Re: External Sound Card - 01-21-2009, 12:26 AM
Yes, I do work alone. Part of the day I am in a four room equipment shop, where I assemble ventilators and other respiratory equipment. I can listen as loud as I want.
MSI P45 Platinum
BFG 8800GT OC
Accelero S1V2
Antec Nine Hundred
Vista 64 Ultimate
LG Flatron W2452T
Default Re: External Sound Card - 01-21-2009, 12:31 AM
Ok. In that case, sound quality is secondary. Get some good amplified speakers (e.g. not Bose).
Default Re: External Sound Card - 01-21-2009, 01:08 AM
Cool, I will give those a try before I get a card. Thanks for the idea.
MSI P45 Platinum
BFG 8800GT OC
Accelero S1V2
Antec Nine Hundred
Vista 64 Ultimate
LG Flatron W2452T
slwiser slwiser is offline
Default Re: External Sound Card - 01-21-2009, 01:13 AM
Use a Nuforce Icon Mobile or iBasso Boa or D3 or D10 or Headroom Total Bithead for an external sound card via USB. I have three of those noted soundcards.
Obsidian Black Mini9 - XP Pro - 16gb SSD - 16gb SDHC - 2gb RAM - Bluetooth - 1.3 webcam
« When will dual core Atoms be in minis? Windows 7? | Remote Control »
