eugene eugene is offline
eugene's Avatar
Default Runcore SSD problem - 05-07-2011, 01:13 AM
Well I got my 16GB SSD Runcore replacement after a month, and I've just installed it in my Mini 9 running XP. It boots up, runs for a while and then I get a Blue Screen, "A problem has been detected and Windows has shut down to prevent damage......."
I've tried a clean XP re-install, no good. Also tried the new SSD in my other Dell Mini and it only runs for a short while before I get the same message. I'd be glad of any ideas. Thanks!
Default 05-07-2011, 01:59 AM
It reads to me as if you need a re-replacement.
eugene's Avatar
Default 05-07-2011, 02:55 AM
Hmm.. that's what I thought too. Thanks very much for the quick reply! I wonder if I will need a re-re-replacement shortly. Doesn't say a lot for Runcore really does it.
Default 05-07-2011, 04:57 AM
It's the luck of the draw I have one original runcore 64gig SSD, and one only just over a year only. the original SSD is 2 years old and going strong. They were the beat out there for a while but the mini 9 is now a dated and unique unit which are slowly reaching their respective use by dates.
eugene's Avatar
Default 05-07-2011, 06:33 AM
Consistency, is the sign of a good product. Three in less than a year, (so far), speaks for itself I think.
« USB not recognized april 2011 | asking for SATA drive in Chinese »
