LeeU LeeU is offline
Default Mini 1012 will not boot from dvd ot thumb drive - 03-20-2011, 12:04 AM
I'm trying to install a new HD but it will not load from either a DVD or a thumb drive, gives errors that a multimedia cable is not hooked up and no operating system, when I put the old HD in it works fine. I did go into bios and set the boot order to dvd or thumb drive when trying to get it to work, I made my bach on the td and dvd from the back up portion in windows. I did do an upgrade to W 7 Home Premium and never did make a back up of the W7 Starter, is that my problem?
Thanks,
LeeU
Default 03-20-2011, 01:01 AM
Is "Legacy USB" enabled in the BIOS? Make sure it is.
Default 03-20-2011, 01:13 AM
I read about Legacy USB before I asked my question but I did not see it any where, where in the Bios is it located?
Thank You,
LeeU
Default 03-20-2011, 12:51 PM
I don't know the 1012. Just cycle through the pages until you find it. May be on the Boot page.
Default 03-20-2011, 08:03 PM
Updated the bios from 7 to 11, still nothing at all in bios named legacy bios, I do have all the usb items enabled, still nothing.
LeeU
---------- Post added at 02:03 PM ---------- Previous post was at 01:57 PM ----------
OK, just checked my Alien Bios, the legacy Bios is not called that, I'm dumb, I do have all the usb items enabled.
LeeU
Default 03-20-2011, 08:57 PM
Does the BIOS show the new drive ok? Don't have other ideas right now.
Default 03-20-2011, 11:21 PM
Yes it shows the drive fine, wondering if the drive is bad, brand new Intel X25 120 GB SSD.
LeeU
Default 03-20-2011, 11:26 PM
That would not prevent a USB or CD from booting. I assume these boot ok on some other PC?
Default 03-21-2011, 01:32 AM
I just tried another drive I had laying around, a new 7200RPM 320 gb, it has the same problem so it is not th drives, it has got to be the Dell restore software, as I have burned it onto DVDs twice, reformatted and copied it on my thumb drive 3 times with no success. I may try to clone a drive instead.
LeeU
---------- Post added at 07:32 PM ---------- Previous post was at 07:31 PM ----------
holmes4,
Thanks for helping me the last few days, I appreciate it.
Lee
« No task bar - help | Dead SSD, but have Ubuntu »
