Tiskers Tiskers is offline
Tiskers's Avatar
Question Setting up GPS? - 12-24-2010, 11:51 PM
Hi, newbie here.
Just got my Dell mini 1012, supposedly with the integrated GPS. Well, it doesn't seem to be "activated". I keep getting a balloon message saying, "Dell wireless location and GPS service is not started".
What should I do? Anyone with any experience with this?
MANY THANKS!
Lynn
Dell Inspiron 1012 purchased 12/20/10; Intel Atom Processor N450 (1.66GHz, 512K L2 Cache); 1GB DDR2 SDRAM; 10.1 inch Widescreen Display (1366x768); Integrated 1.3M Pixel Webcam;Crystal HD Broadcom Media Accelerator; 250GB 5400RPM SATA Hard Drive; Windows 7 Starter Label; 56WHr Lithium-Ion Battery (6-cell); Built in GPS with Turn by Turn Navigation Software; Bluetooth 2.1 module with EDR, DAO-- all in a snazzy black sleeve!
Default 12-25-2010, 01:22 AM
"service not started" indicates a windows message, windows starts several processes/services when it boots, there can be many reasons for a process/service not to start...I dont have GPS but is there an option in the BIOS for it to be enabled?...also if you go into device manager in windows and look at the GPS, is it there? or is there a yellow triangle?..is there a dell utility to turn it on like with bluetooth and wifi there is a radio switch utility that you need to turn on/enable..maybe its the same with GPS
Tiskers's Avatar
Default 12-25-2010, 02:01 AM
Thank you (again!) for the reply. I really appreciate it!
YIKES,though - your suggestions are beyond my scope of understanding... will have to ask dear husband for help!
But thank you SO MUCH for taking the time to reply!
Lynn
Default 12-25-2010, 04:01 PM
Lynn, I suggest you contact Dell for help with this. They'll know about the hardware and software they provided, and as your unit is new it is still under warranty. It does sound as if some Dell-specific software is either not installed or not working properly.
I think the first thing I'd try is to download and install the Dell software for the GPS module. There are two, driver and application. Install these both, in that order, and see if that helps.
« Windows Phone 7 | Dell Outlet Laptop »
