KC6TTR KC6TTR is offline
Default 32GB SATA II and USB Internal/External 2.5" SSD - 12-30-2008, 04:45 PM
This is pretty cool for normal laptops or using as an external drive on the Mini 9. The speed looks decent and the price is pretty good as well @ under $80.
32 GB 2.5 SSD
Sequential read/write: 130MB/sec & 90MB/sec
Random read/write: 80MB/sec & 25MB/sec
Noiseless (Acoustic = 0dbB)
Ultra-durable (Operation temperature 0C to 70C and withstands Operation shock 15000G)
Low power consumption (5V, 200mA)
Complete metal casing
Mean time before failure (MTBF): 1,300,000hrs +
Access time: 0.1ms
SATA II (when used as internal)/USB 2.0 (when used as external) Interface
Dimensions: 2.75" x 3.94" x 0.31"
Weight: 0.2lbs
http://www.buy.com/prod/cavalry-pelican ... caid=17653
Scott-
strider_mt2k's Avatar
Default Re: 32GB SATA II and USB Internal/External 2.5" SSD - 12-30-2008, 04:52 PM
That is pretty darn cool.
I don't think I've seen a drive like that before with the USB connector built in.
Default Re: 32GB SATA II and USB Internal/External 2.5" SSD - 12-30-2008, 05:18 PM
Yes, it is... 8-)
I just wish they would also include a cap for the exposed SATA II header pins. However, I would imagine (hope) that section of the device is disabled via the onboard controller if the USB interface is active.
Scott-
« Dell service | SSD drive for my other Dell laptop? »
