Default 12-08-2009, 12:52 AM
Any recommendations as to leaving it running or shutting down with an SSD?
Typically now I leave it running all the time and have minimal programs running/set to start at start up.
I'll also use Imagex to grab an image after I get everything installed.
C:\M11xR2\320GBHD\4GBRAM\W7HP
D:\duo\320GBHD\2GBRAM\W8DP
Default 12-08-2009, 01:30 AM
If you're not going to be using it for a long time, I'd put it in standby. Fewer writes to the SSD and lower power consumption. But if you like leaving it on, do so.
« New Site! | Dell Support Terrible - AND Where Is My Order? »
