rr0123 rr0123 is offline
Default Will the 10v ever have HD screen? - 07-08-2009, 06:56 PM
Does anyone know if this is planned? Looks like the outlet has regular 10s pretty cheap with a coupon, so I am thinking of getting one even though it means no OSX or 2gb ram.
somms somms is offline
somms's Avatar
Default 07-08-2009, 07:09 PM
Nope...the HD LED screen won't be avail for the Mini10(v)=value model.
psyopper psyopper is offline
Default 07-08-2009, 07:47 PM
I wonder again at the viability of a swap though. The original 1024x576 didn't swap because it was a different physical part. I do wonder about the new 1024x600 screen. If it's the same part as the 1010 screen then viability options definitely go up!
http://shop.psyopper.com
« Hey thought you hguys might be intrested | Dell mini's with ION = OS X compatible? »
