ultralow ultralow is offline
Default Re: WARNING - 03-05-2009, 02:27 PM
Mine's ok, too.
Neo_Reloaded Neo_Reloaded is offline
Default Re: WARNING - 03-05-2009, 02:44 PM
Using DellEFI 1.1 beta 2 and updated with new updates and my Mini is working with no troubles!!! Maybe there is something broken in your installation, try to run DellEFI again.
DELL Mini 9 - 2Gb RAM - 32Gb RunCore SSD - BIOS A05 - OS X Leopard 10.5.7
guyincognito guyincognito is offline
Default Re: WARNING - 03-05-2009, 06:22 PM
I encountered the problem reported by the OP. I had to boot with -f in order to get the OS to boot after installing the updates, at which point the Airport card was not recognized. I reinstalled DellEFI, and now everything seems to be working fine.
  (#14) Old
mechdrew mechdrew is offline
mechdrew's Avatar
Default Re: WARNING - 03-05-2009, 06:28 PM
Works fine here too, typing from it. Try reinstalling DellEFI before panicking next time.
  (#15) Old
Tohsh Tohsh is offline
Default Re: WARNING - 03-05-2009, 07:01 PM
Rerun DellEFI and make sure to check "Reinstall Mini 9 extensions"
Alpine White Mini 9
OSX 10.5.6
HDD Activity LED
  (#16) Old
AlecEdworthy AlecEdworthy is offline
Default Re: WARNING - 03-05-2009, 08:31 PM
Nothing to do with the Dell Mini but I installed all the available updates on a MacBook Pro last night (10.5.6 first, rebooted and then used software update) and the airport on it is dropping out now :-(
Dell Mini 9 (UK), 16Gb SDD, 2Gb RAM, Mac OS X 10.5.6
  (#17) Old
kellgy kellgy is offline
Default Re: WARNING - 03-05-2009, 10:55 PM
I lost my wifi and other settings after upgrading to 10.5.6. Then I reinstalled the DellEFI and booted twice and everything worked again. I used the "easy installation" settings in A.12 on the excellent "How-To: Install Mac OS X - DellEFI Method" thread.
Mini 9 white, 2GB ram, 32GB SSD (Dell's), OS X DellEFI method
« Snow Leopard | Introduction / Comments »
