(#21)
| Junior Member Posts: 3 Join Date: Mar 2009 | Yeah, chosing that choice will get you nowhere... you have to hit esc here and then either type 81 or 82 (try the other if the first one doesn't work). I had a lot more luck following the DellEFI Method: how-to-install-mac-os-x-dellefi-method-t3925.html Which is more or less a newer version of the Type11 guide and has USB install instructions, which is where I learned this step. The USB disk image is newer, too, so don't forget to download that and copy those files over to your boot stick before you get to this part. |
« HELP: Noise in sound
PDF »
