(#11)
| Senior Member Posts: 122 Join Date: Feb 2009 Location: Portland, OR | Quote:
(#12)
| Junior Member Posts: 2 Join Date: Feb 2009 | hello everyone. i'm japanese sorry for my strange english. so, i want to try USB Install. i have a retail copy of Leopard. but i don't have "Intel Mac". how can i make Leopard .iso? please help me |
(#13)
??????????????????????.iso???????????????DVD?????? ?????? | |
(#14)
| Junior Member Posts: 2 Join Date: Feb 2009 | Quote:
????????????????????? ????????????????? ???PPC???????????????????? ??????????????????????trancemac????USB???????????? ???????????????????? ?????trancemac??????????????????????? ???? Re: How to: USB Install (no DVD drive) (#p30278) by charlie66 on Wed Feb 11, 2009 6:53 pm I created an dmg file of the OS X installer on my iMac PPC. After, I copied that file to my USB key. I used Transmac to copied that dmg file to my Thinkpad. I needed to umcompressed the dmg file and then used the uncompressed dmg to format my USB key. But when I selected 81 at the boot process, my USB Key wasnot recognize as a OS X installer. Maybe my USB key is bad. ????boot process?80-83?????????????????????????????????????? mini9?????????????????????????????? ????????????????? | ||
(#15)
| Junior Member Posts: 12 Join Date: Mar 2009 | No files were put into the USB after I ran the command. Is that normal? |
(#16)
| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | Quote:
http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter | |
(#17)
| Junior Member Posts: 12 Join Date: Mar 2009 | Quote:
Thanks, I'll try it out. Also thanks for the reply in the other thread, just saw it a min ago. | ||
(#18)
| Junior Member Posts: 3 Join Date: Mar 2009 | I'm having a little trouble getting my sticks to boot. I'm using two Patriot Xporter XT Boost sticks, a 4 GB for the boot ISO, and a 16 GB for the DVD image. I can only get the machine to boot off the boot ISO stick if I enable legacy usb bios mode in the Mini 9 BIOS (running A04 now, 16 GB SSD, 1 GB factory RAM). When it does come up, it says something like: Quote:
| Junior Member Posts: 3 Join Date: Mar 2009 | Nevermind, following the DellEFI guide now and seeing where I should have hit escape and typed that other address. Sorry! |
(#20)
| Junior Member Posts: 1 Join Date: Mar 2009 | OK. I have the Boot123 USB stick (lefthand side of Mini) successfully starting up the boot loader. However when I press enter to install OSX image from the USB stick with the restored Leopard image on it (righthand side of Mini), I get a screen saying: loading cdfiles/retail.img........................................ .............................................. then a screen saying: Darwin/x86 boot etc Select start up volume - the only choice available here is "hd(0,1)" EDIT: Okay didn't realise there more >1 page of comments and that I'd asked the same question as the last postee. I've also realised that you press Esc at the above point then type 81 or 82 to get it to boot from the larger USB stick containing the OSX installer image. I'm now on the intalling progress bar but needed to do a clean install (i.e. delete the internal disk's contents) and remove EVERYTHING in the OSX install options (extra languages, print driver, X11 etc) to get OSX on my 8GB internal drive. Even so it only leaves 9MB! Guess I'll need to remove the PPC side of things. |
« HELP: Noise in sound
PDF »
) i do believe it's an intel. it has an intel processor listed in "about this mac." It's one of the "older" solid white macbook laptops (one that came out right before the new ones with the "no button" mouse) it's running tiger (i don't know if that would affect it) ... but i am pretty sure (95%) it was because i wasn't using a retail version of osX. Being the dumb dumb that i am i have been trying to avoid it. But...i have it on order from my school bookstore. (only $69!!!
) so hopefully it will be in by next week sometime. I have been trying to get it for a week now but with a price like $69 its has been flying off the shelf.
