| Junior Member Posts: 3 Join Date: Feb 2009 | Has anyone heard of the Super Talent 32GB MLC Half Mini PCI-E Solid State Drive? I have found a vendor with product in stock, 32Gb for $89. • Mfr Part Number: FEM32GHDL • Interface: Custom PCIe • Capacity: 32 GB • NAND Flash: MLC • Performance: o Sequential Read Rate: 40 MB/s (max) o Sequential Write Rate: 15 MB/s (max) o Operating temperature: 0°C to 60°C o Power Supply: 3.3Vcc ±5% o Dimensions: 30 x 51 x 3.5 mm o 1 year warranty o Works with the Dell Inspiron Mini 9 netbook It would be nice to save $30 and get one quick!! |
| Retired Mini user Posts: 1,577 Join Date: Oct 2008 | If price was your number one consideration then it's a good deal. But those rated speeds are very low compared to the RunCore drives. If I was in the market for a 32GB drive, I would spend the extra $30. |
| Junior Member Posts: 3 Join Date: Feb 2009 | RunCore Specs FYI MPN RCP-I-M5032-C ATA/IDE Interface ATA-6 Compatible Capacity 32GB ATA Transfer Mode UDMA 0-6, PIO 0-4 Support TrueIDE Performance Sustain Read Speed up to 78MB/s Sustain Write Speed up to 44MB/s Grade Commercial Temperature 0C to 70C Operating Voltage 3.3v Data Retention 10 Years Read/Write Lifetime 10,000 R/W ECC Correction Built-in ECC Dimensions Length: 25.70 ± 0.10 mm Width: 50 ± 0.10 mm (2.006 ± 0.004 in) Height: 3.50 (0.138) max Compliancy RoHS-6 Compliant |
(#4)
| Junior Member Posts: 25 Join Date: Feb 2009 | I came across those as well, but as was said, those speeds are terrible. 1/2 the read and 1/3 the write performance. |
(#5)
| Junior Member Posts: 3 Join Date: Feb 2009 | I also came across one from Buffalo but could not find a place to buy it. Patriot Memory has one for the Asus EEE and should have the Dell Mini version out soon. Now don't anybody but a SSD till i do because I know the day I do, all the prices will go down by at least one third. |
(#6)
| Retired Mini user Posts: 1,577 Join Date: Oct 2008 | If you would rather save money, Crucial has a 32GB drive. http://www.crucial.com/store/mpartspecs ... C5A5CA7304 |
(#7)
| Senior Member Posts: 208 Join Date: Feb 2009 | but arent the supertalents the ones that dont fit the mini?? did they resize it or something? --edit-- ah geeze. just saw that it was HALF mini pci-e... but yeah, if you can double your speed with a runcore for only $30 more, do the runcore ^_^ |
(#8)
| Junior Member Posts: 25 Join Date: Feb 2009 | The Crucial has the same specs as the Super Talent... Notso good. |
(#9)
| Guru Posts: 1,744 Join Date: Sep 2008 Location: Olalla, WA | Not so good? heh, you will hate life! I had an SSD with that kind of performance. MyDigitalDiscount used to sell them.. They were so bad they discontinued selling them. |
(#10)
| Junior Member Posts: 10 Join Date: Feb 2009 | Just FYI I chatted with someone from MyDigitalDiscount yesterday and they told me that they should be restocking the 32 and 64 GB drives mid to late next week. I'm holding out for a 64 GB for my wife's new Mini (that she doesn't even know she has yet). Dwayne |
