Default Brainstorming the Sleep issue - SOLVED. - 10-18-2008, 05:35 PM
If you are finding this thread in the future, the sleep issue has been solved. Sleep will not work on the factory STEC SSD. Simply swap it for another brand and you will have functional sleep.
Default Re: Brainstorming the Sleep issue - 10-18-2008, 07:26 PM
Hi, ive reading your post and many more, regarding the sleep issue, but it wasn´t until you mention this that I realise something I saw in jkkmobile.
In the following video, the guys at JKKmobile, taped a couple of pins on a PCI-e WWAN Card in order to use it with the Dell Mini 9. They did this method with the pci-e slot used for the WLAN card but maybe we are seeing something similar with the SSD.
I dont have my MINI 9 yet, but maybe you can give it a try.
This is the JKKmobile post:
http://jkkmobile.blogspot.com/2008/1...ni-9-easy.html
And this is a similar problem found at insanelymac forum:
http://www.insanelymac.com/lofiversi...hp/t15659.html
L
Default Re: Brainstorming the Sleep issue - 10-18-2008, 08:23 PM
Yeah, that's where I got this idea.
Default Re: Brainstorming the Sleep issue - 10-18-2008, 09:13 PM
I think it is more along the line of OS X's Safe Sleep feature. Somewhat like Windows hibernation, where the state of teh computer is saved to memory, so if the battery is taken out, a power-failure, or anything make the computer turn off, it will remember where it was before it did. So my guess is, similar to the issue with certain pins you mention, this could maybe be solved by disabling the Safe Sleep feature.
Send a message via MSN to mrwolff
Default Re: Brainstorming the Sleep issue - 10-18-2008, 09:55 PM
I was thinking maybe the best way to see if this is the case would be to check it with a multi meter on the lines that they soldered on jkkmobile's site. See what is running through it before sleep and then after? Maybe it really is cutting power to the drive?
Everything that is down can go up, but only some of what is up can go down.
|Type11 EFI 10.5.5, 2gb, Touch screen in progress|
Default Re: Brainstorming the Sleep issue - 10-18-2008, 10:21 PM
Yeah, We've already tried that. It's a pretty simple command you type into the Terminal.. It was tried and made no difference to the problem. It was a good theory though.
Default Re: Brainstorming the Sleep issue - 10-19-2008, 05:09 AM
IIRC there were reports on the insanelymac thread about the mini that sleep fails even if the mini boots from an external USB drive, so I don't think this will help.
Default Re: Brainstorming the Sleep issue - 10-19-2008, 02:08 PM
I can confirm that for me sleep will not work even from an external hard drive.
Dell Mini 9 | 32GB SSD Runcore | 2GB RAM | 1.3 mp WebCam | OS X 10.6.2 | USB Wake Off | Legacy Support Off | Bluetooth Module On | A05 bios | NBI 0.8.3RC3 | Geekbench 2 Score 985 |  Mac Pro 2008 | 2 X 2.8 GHz Quad Core 45-nm Intel Xeon E5462 (Harpertown/Penryn) processors | 16GB 800 MHz DDR2 Ram | ATI Radeon HD 2600 XT 256 MB GDDR3 | Geekbench 2 Score 12296 |  MacBook Pro 13" (Mid 2009) | 2.53GHz Intel Core 2 Duo P8700 4GB 1066MHz | Geekbench 2 Score 3907 | http://tinyurl.com/y9gu2f7
Default Re: Brainstorming the Sleep issue - 10-19-2008, 06:50 PM
I'm hoping battery life will be acceptable with sleep mode disabled and just using InsomniaX to turn the LCD off when closed. Does anyone have numbers?
I'm still waiting on my unit and hope to get OS X running well enough to be my little road warrior.
Failing that, I'll be sending it back. Maybe by the time it arrives the scene will have figured the sleep problem out? I'm sure more units in more "hackers" hands = better chances of success. Dell needs stick the whip to their production facility.
Dell Mini 9: Black, 8GB SSD, 1GB RAM, Bluetooth, No Webcam, Windoze XP
Ordered: 10/10 Canceled: 10/30, Re-ordered Via Outlet, , , , , , , , ,Estimated Delivery: 11/3
Default Re: Brainstorming the Sleep issue - 10-19-2008, 07:00 PM
You do not need InsomniaX, there is a command in one of the threads here (if someone has it handy, this would be a good thread to post it in). No need for an extra app running taking up resources. And yeah, when you shut the lid after disabling sleep with that command, the screen turns off, which might help battery life some.
« HowTo: Install OS X on the Mini9 (Boot132) Original Thread | Error checking a PM »
