Wowzer Wowzer is offline
Default Static Noise is feedback? - 02-07-2009, 05:04 PM
Hi All,
First, I wanted to say thanks for having this forum for MacOSX installation and for the references to the EFI and 132 ISO.
Second, I am not sure if there is a reason why the static noise was thread was locked.
Thirdly, I believe that the static noise issue is feedback from the microphone. Why? When I turn the sound up and down via software, the static will also vary. When you turn the sound off and then back on again, the feedback static gone.
Default Re: Static Noise is feedback? - 02-07-2009, 07:43 PM
It was locked because we got confirmation that it was a hardware issue. Very few people have the problem, it's not going to be solved via software.
« In a bind? Use a USB-to-IDE and old CD/DVD-ROM drive! | Second SSD? »
