Default Discussion of the Type11 EFI Method - 10-17-2008, 04:10 AM
This thread is for discussing the Type11 Boot132 Retail OS X install method.
If you plan to run OS X, you really really should buy a copy from Apple. The price is very reasonable, it's obviously a great OS, and deserves the small price they charge for it. Once you do that, you'll have a retail copy.
Default Re: Type11 EFI Method - 10-17-2008, 06:54 AM
Originally Posted by UnaClocker
Sweet sweet. I like this method, and plan to go this route when my 32gb SSD arrives.
Yeah, it's also the best method I've tried so far, thanks again Type11!
And definitely please keep us up to date on that 32gb drive!
Dell Mini 9: Obsidian, 2gb ram, 16gb hdd, bluetooth, 1.3mp webcam, Mac OS X 10.5.5
Default Re: Type11 EFI Method - 10-17-2008, 09:55 PM
I'm trying to use this method to dual boot XP and OSX on a 16gb SSD. 5gb to windows, and the rest to OSX. Not too bad, OSX has about 2GB free and windows has about 2GB free. Here is the problem. With this method, leopard will not install unless the partition is GUID. XP Will not install GUID, it needs to be MBR. It's my understanding that OSX can be installed MBR, but it's not letting me. It has a big red mark over the drive and says format GUID to fix. How, using this method, do I install OSX MBR?
Also, for those of you wondering about my lack of free space, I'm going to do an internal mod with a 32gb ssd. 32gb is enough for a few movies and programs etc....
Default Re: Type11 EFI Method - 10-18-2008, 12:54 AM
Internal mod? The SSD unscrews, you buy the one that fits, and screw that into it's place. No big deal.
As for MBR, try iAtkos, it might support MBR.
Default Re: Type11 EFI Method - 10-18-2008, 02:04 AM
Yeah this method is for guid only. iAtkos would work for MBR.
Default Re: Type11 EFI Method - 10-18-2008, 02:41 PM
Think I got quartz extreme issues worked out new iso posted let me know
Default Re: Type11 EFI Method - 10-18-2008, 02:51 PM
What did you change? Just added new kexts?
Default Re: Type11 EFI Method - 10-18-2008, 05:26 PM
Hi Type11, I'm typing this on my "Dell MacBook nano" using your previous iso, thank you so much for all your work on this! I am having QE issues, so I downloaded your new iso. Unfortunately now when I try to mount the new install.dmg I get the following error: "The following disk images failed to mount: INSTALL.DMG. Reason: no mountable file systems"
Any ideas? Thanks again, and to everyone wondering if they should install OS X on their Dell Mini, go out and buy the retail copy and do it, it's amazing. (I even took an Apple sticker from the box and covered up the Dell logo on the lid to create the perfect MBnano.)
Default Re: Type11 EFI Method - 10-18-2008, 05:48 PM
Yeah I had added IONDRVSupport to my kext while back as there was an error on bootup. However this never kept me from getting QE to work just thought it was more complete. Smoothy Boothy on the other website said that IOPCIFamily helped him with the problems so I added it. I already had IOGraphicsFamily so I did not change that. Again I don't see the issue but I am thinking this will have a good shot at fixing it for others. Let me know how it goes.
Also from the other thread if you already install my way and do not have QE then downlaod this new iso, mount it, and mount install.dmg and rerun miniscript this hopefully fixes it
Again let me know everyone!
Default Re: Type11 EFI Method - 10-18-2008, 10:25 PM
Just wondering, but would doing a fresh install of the kexts possibly help my problem with OS X not always booting up on the first try?
I have another question... so far I've tried installing a couple of utilities (Coolmaster, Sidetrack, etc.) and upon re-booting, I get an error message telling me that the extension was not installed, and I need to reboot. No matter how many times I reboot, always get this message and software is unusable. Any ideas?
« My RunCore SSD 64GB is now working :-) | Why not MSIWind method? »
