| Expert Member Posts: 962 Join Date: Dec 2008 | I have found a workaround to the problem of the spinning beach ball after resuming from sleep and forgetting to eject your SDHC card. This happened to me many times and I needed to find a solution. Here is what I found work for me. Maybe you will find it helpful. What you need: 1. Type11 v7.5 installation (7.1 will probably work also) 2. sleepwatcher from http://www.bernhard-baehr.de/ 3. Some time Solution: 1. Open your install.dmg and move the kext IOSDHCIBlockDevice.kext from Extentions to LocalExtensions 2. Run miniscript and only perform an update. This will copy IOSDHCIBlockDevice.kext to your local System/Library/Extensions. IOSDHCIBlockDevice.kext does not need to be in the EFI partition. 3. Install both "Sleepwatcher" and "Sleepwatcher startup" (contained in the same dmg) 4. Add the following to the end of /etc/rc.sleep Code: umount -f /dev/disk1s1 sleep 1 kextunload /System/Library/Extensions/IOSDHCIBlockDevice.kext/ Code: kextload /System/Library/Extensions/IOSDHCIBlockDevice.kext/ This should be helpful until a fix is found for the sleep issue with the SDHC kext. Note that Sleepwalker take about a minute to kick in... so when testing wait a little bit before putting to sleep. I tried something similar with teh AppleHDA.kext extension to try to resolve the audio issue but unfortunately it does not work. Maybe someone can find the right kext to unload/load to get audio working again in the same manner? 8GB SSD, 1GB RAM OS X 10.5.6 |
| Junior Member Posts: 13 Join Date: Dec 2008 Location: Kennewick, WA | Nice work, although something isn't working quite right for me. When I close the lid, sleep is engaged but on waking I get a device removal error (you know, the device was not yada yada). After a second or two the SD card mounts and all is good but I'm a little worried about delay writes to the card. By the way, same happens if I use sleep from the Apple menu. I've restarted a couple of times too, in case that was the issue. Any ideas appreciated. A. EDIT: Running df in terminal shows my SDHC to be /dev/disk1s2. Making that change in rc.sleep makes everything work okay. Thanks again! 2GB RAM :: RunCore 32GB SSD :: Bluetooth :: 1.3Mp Webcam :: Custom Keyboard Map Mac OS X 10.5.6 (Type11/Boot132 v8.02b1) :: iLife '09 :: Microsoft Office 2008 |
| Member Posts: 88 Join Date: Nov 2008 | Just as an FYI, km9 has fixed the sleep problem the right way (the driver now knows how to sleep and wake up) so this fix shouldn't be necessary once we do the next release (probably no later than Sunday evening) of the driver. |
(#4)
| Expert Member Posts: 962 Join Date: Dec 2008 | I just loaded the new kext and all is good without the sleepwalker trick! So go for it! 8GB SSD, 1GB RAM OS X 10.5.6 |
