Posts: n/a
Default Bluetooth GPS Receiver - 04-24-2010, 11:46 PM
Please see pix below...
This is a NEW Bluetooth GPS Receiver that would make an awesome addition to your mini setup - make your netbook into a mobile device - in the full sense of the word.
$59 or best offer U.S. / PayPal only. (pm me here or
Couple of things to note: (1)This has an internal, rechargeable lithium ion battery, but only a car charger - so you'll have to charge it in the car, but then that's really what it's main purpose is - to be used in the car of course. And (2) You will, of course need to get navigation/gps/map software on your device - this is only the receiver.
That being said, it will fit nicely on the dash or wherever you want, this is VERY highly rated - serious GPS - it has WAAS capability. That drops positional error down to less than ten feet, and is a lot less expensive than the usual vehicle GPS
Here's the full spec's:
1. Wireless GPS using Bluetooth technology.
2. Communicate with Host Platform via Bluetooth Serial
3. SiRF Star II/LPor X-Trac high performance and low power
consumption chipset.
4. All-in-view 12-channel parallel processing.
5. Built-in SuperCap to reserve system data for rapid satellite
6. Supported NMEA 0183 command:GGA, GSA, GSV, RMC,
7. GPS/Bluetooth/Battery LED indicators.
8. Non-slip on the bottom.
9. Built-in Lithium-ion rechargeable battery.
Channels 12 parallel channels
Output Messages NMEA 0183 V2.2 protocol and supports
Hot Start 8 sec., average
Warm Start 38 sec., average
Cold Start 45 sec., average
Acceleration Limit < 4g
Altitude Limit 18,000m
Re-acquisition 100ms
Velocity Limit 515 meters/sec
Time Accuracy 1us synchronized to GPS time
Position Accuracy 15m 2D RMS without SA
5m 2D RMS WAAS enabled
Supply Voltage Build-in rechargeable battery and 5V DC input charging circuit
Operation Time 8hr after fully charged, in continuous mode
Bluetooth Specification
Bluetooth V1.1 compliant
Frequency 2.400~2.480 GHZ
Sensitivity -80 dBm
Transmit power Class2
Transmit Range 10M
Dimension 84mm*47mm*27mm
Storage Temperature -30°C ~ 80°C
Operation Temperature -20°C ~ 70°C
Humidity Up to 95% non-Condensing
Posts: n/a
Default Price dropped - 05-04-2010, 12:46 AM
Price dropped to $39.99
Posts: n/a
Default sold..... - 05-19-2010, 11:27 PM
« Mint 10V | Serious Mini 10 upgrade package deal!!! Must view this post! »
