| Senior Member Posts: 124 Join Date: Dec 2008 | The instructions at the OSX86 wiki for installing Leopard on the Mini by using two USB Drives say: Quote:
It says that you have to restore the DVD (or ISO) to the USB stick. If I have a .DMG of the retail version of Leopard, do i do the same (ie. is that the same as an ISO). Also, how do you use the restore function of Disk Utility? | |
| Member Posts: 48 Join Date: Nov 2008 | White mini9, 802.11n, 2G RAM, 16G STEC HD, BIOS A05, Mac OS X 10.6.7 Red mini9, 802.11n, 2G RAM, 16G Runcore HD, BIOS A05, Mac OS X 10.6.7 |
| Senior Member Posts: 124 Join Date: Dec 2008 | Do I follow the same instructions for a DMG as I would for an ISO? |
(#4)
| Guru Posts: 1,744 Join Date: Sep 2008 Location: Olalla, WA | Probably. DMG's are just an apple take on an ISO.. ISO's tend to only be images of CD's or DVD's.. DMG's can be images of any drive. |
(#5)
| Senior Member Posts: 124 Join Date: Dec 2008 | Could you give me step by step instructions in restoring the Leopard dmg onto a flash drive please? Thanks! |
(#6)
| Guru Posts: 1,744 Join Date: Sep 2008 Location: Olalla, WA | This is already covered in this thread: usb-install-t421.html |
