  (#31) Old
Default 02-06-2010, 08:33 PM
can we use a memory stick pro duo 8gb for the install?
  (#32) Old
Default 02-06-2010, 08:35 PM
If you have a USB card reader for it, yes. If not, no.
  (#33) Old
Default 02-07-2010, 12:08 AM
a usb card reader? say if i used it through my psp would it work?
  (#34) Old
Default 02-07-2010, 12:11 AM
Umm, I'm not sure how the 10v will boot from a PSP. Can the PSP act as an external hard disk via USB interface? If so, it might work.
But I would be willing to bet that it won't. Sony of all companies goes out of their way to make their stuff incompatible with the rest of the world.
  (#35) Old
Default reuse snow leopard disk? - 02-08-2010, 03:53 AM
I'm considering hackintoshing a 10v, and I currently have a Snow Leopard upgrade disk which I already used to upgrade my macbook. Would using the same disk work for this hackintosh?
  (#36) Old
Default 02-08-2010, 11:44 AM
Technically, yes it will work. The 'upgrade' disk contains all the code of the full version disk.
Ethically, I would encourage you to buy an additional license. The Snow Leopard End User License Agreement stipulates that
1) you install the upgrade on only one machine per license
2) that the machine be built be Apple
3) that the machine already have a legal copy of Leopard on it. If your Macbook was running Tiger, the EULA requires you to buy a "full" non-upgrade license that costs $169.
We obviously can't obey (2) with a hackintosh. (3) seems a bit insane for a device that only costs $300 or less, and even Apple has made no attempt to enforce it with their installer, which will install with no problem on a Tiger system. But in order to maintain some vestige of ethics, an additional $29 for a new DVD seems worth it.
  (#37) Old
Default 02-08-2010, 03:30 PM
This was an excellent guide! I love my Dell 10v now!
Question...would this method also work for my Dell Inspiron 14 (1440)? The wireless module is the same in both (1397). Wasn't sure if other components and drivers would work too. Thanks!
  (#38) Old
wtb wtb is offline
Default hackintosh failure - ideas? - 02-09-2010, 12:26 PM
I tried the mini10v hackintosh. I've reached the point almost at the end of the process, where it says "installation successful" (for Snow Leopard) on the 10v. When it re-starts, however, the Dell logo comes up briefly, followed by a black screen with a blinking cursor in the top left-hand corner. This seems like it will last indefinitely (I've let it last a couple of hours). When I restart, the same thing happens, although I'm able to use the F2 function at the Dell start-up. I tried the whole process again from the very beginning, and the same thing happened a second time. Does anyone have any idea what is going on? Any suggestions? Thank you!
  (#39) Old
Default 02-09-2010, 03:45 PM
It sounds like chameleon, the bootloader, is not detecting your Snow Leopard install.
I'm assuming here that you built your installation USB with NetBookMaker 0.8.3 alpha, the latest version.
Restart your 10v with the Snow Leopard (SL) USB inserted, and boot to the SL installer. Once it loads to the first installer window, select your language and then go to the next step. From the Utilities menu at the top of the screen, select "NetBookInstaller" (NBI). When NBI loads, select your internal hard drive as the target and run it with the following options selected:
-install Chameleon
-install 10v extensions
-disable hibernate
-regenerate DSDT.aml
You can also choose:
-enable quiet boot (if you don't intend to multi-boot)
-enable remote CD
-enable bluetooth (if you have a BT module installed)
Run NBI. It will take several minutes. After that, go to the apple menu and exit the installer. Remove the USB stick and reboot. See if that fixes it.
-virusdoc
  (#40) Old
wtb wtb is offline
Default 02-09-2010, 05:26 PM
Thank you very much for the quick reply and the suggestion. I tried your suggestion, but unfortunately, it didn't work. Yes, I used the latest version of NetBookBootmaker. The BIOS is A06, but I gather that shouldn't be a problem. Also, if I boot from the USB and go to start-up disk in the disk utilities, it doesn't list the HD as an option (only network). I don't know enough about these things to know if this means there's a problem.
« Hi!!!! I'm desperate | Installation of Snow Leopard on Mini 10v »
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/17087-how-hackintosh-dell-mini-10v-into-ultimate-snow-leopard-netbook.html
Posted By For Type Date
????? : ?????? snow leopard ??? EeePc 1101HA This thread Refback 10-06-2010 05:51 PM
joelkuehn's hackintosh Bookmarks on Delicious This thread Refback 10-05-2010 08:03 PM
DavilBlog - Tech Geek Stuff: March 2010 This thread Refback 09-30-2010 03:46 PM
bit.ly statistics for (How to Hackintosh a Dell Mini 10v into the ultimate Snow Leopard netbook) This thread Refback 08-31-2010 07:23 PM
iPad uit Amerika halen | One More Thing This thread Refback 08-15-2010 09:59 PM
Popular hackintosh Bookmarks on Delicious This thread Refback 07-05-2010 02:40 PM
hackintosh « Search Results « otherwise This thread Refback 07-04-2010 08:06 AM
breretc's apple Bookmarks on Delicious This thread Refback 06-18-2010 11:58 AM
Hackintosh 10v Trackpad | Lifedork This thread Refback 06-03-2010 01:27 PM
breretc's mac Bookmarks on Delicious This thread Refback 05-06-2010 12:02 PM
breretc's Bookmarks on Delicious This thread Refback 05-06-2010 10:53 AM
dirt's Bookmarks on Delicious This thread Refback 05-04-2010 11:48 PM
How to Hackintosh a Dell Mini 10v into the... - Nick Shue - FriendFeed This thread Refback 05-03-2010 09:46 PM
Pinboard: bookmarks for liedra This thread Refback 04-23-2010 02:51 PM
estiraven's Bookmarks on Delicious This thread Refback 04-14-2010 01:31 AM
iPad uit Amerika halen | One More Thing This thread Refback 04-03-2010 07:45 PM
Osx on ASUS EeePc 1101HA ? - InsanelyMac Forum This thread Refback 04-03-2010 03:57 PM
Mac OS X Snow Leopard 10.6.2 on Dell Mini 10v Guide This thread Refback 04-02-2010 06:24 AM
CWF's HackIntosh_UMPC Bookmarks on Delicious This thread Refback 03-30-2010 08:04 AM
2x (Two) Dell Mini 10v Netbooks: Intel Atom N280 1.66GHz, 1GB DDR2, 160GB HDD, WiFi G, Webcam, 10.1" (1024x600) Screen, Win XP Home, 3-Cell Battery $411 - Page 47 - SlickDeals.net Forums This thread Refback 03-25-2010 05:20 AM
2x (Two) Dell Mini 10v Netbooks: Intel Atom N280 1.66GHz, 1GB DDR2, 160GB HDD, WiFi G, Webcam, 10.1" (1024x600) Screen, Win XP Home, 3-Cell Battery $411 - Page 47 - SlickDeals.net Forums This thread Refback 03-24-2010 04:10 AM
lipbalm's osx Bookmarks on Delicious This thread Refback 03-22-2010 04:22 PM
?230 Intel Mac laptop? Fuck yeah! - Pattaya Forum This thread Refback 03-21-2010 09:43 AM
DavilBlog - Tech Geek Stuff: Making Apps for Phones using only web technologies This thread Refback 03-18-2010 12:57 PM
jaegermister's Bookmarks on Delicious This thread Refback 03-09-2010 10:25 PM
Vilken eeePC ska man välja ? - MacWorld - allt om Mac & iPhone - Sida 2 This thread Refback 02-24-2010 09:27 AM
Anyone here successfully put OS X on a Dell Mini 10v? - Computing and Networks - Digital Spy Forums This thread Refback 02-19-2010 11:53 PM
How to Hackintosh a Dell Mini 10v into the ultimate Snow Leopard netbook This thread Refback 02-12-2010 01:57 PM
MacBook for $279 ~ try a Hackintosh - Page 2 - The Gear Page This thread Refback 02-07-2010 11:38 AM
composizioni's Bookmarks on Delicious This thread Refback 01-31-2010 02:39 PM
How to Hackintosh a Dell Mini 10v into the ultimate Snow Leopard netbook This thread Refback 01-28-2010 11:21 PM
How to Hackintosh a Dell Mini 10v into the ultimate Snow Leopard netbook This thread Refback 01-27-2010 04:26 PM
madmaxmedia's hackintosh Bookmarks on Delicious This thread Refback 01-26-2010 10:03 PM
Anyone here successfully put OS X on a Dell Mini 10v? - Computing and Networks - Digital Spy Forums This thread Refback 01-26-2010 06:37 PM
MacKorisnik.com • Pogledaj temu - Netbook + OS X This thread Refback 01-26-2010 11:37 AM
Dell Mini 10 Guides This thread Refback 01-20-2010 12:26 PM
