(#21)
| Senior Member Posts: 174 Join Date: Dec 2009 | Quote:
Enjoy your hackintosh once it is built. My 10v runs Snow Leopard better than my Macbook Air, and even smoother and faster than Windows 7 runs on the same hardware. -virusdoc | |
(#22)
| Junior Member Posts: 29 Join Date: Jan 2010 | Virusdoc & Montala, Thank you both for your comments and clarifications!! I just ordered my 10v last night so hopefully I will be Hacintoshing soon!! Virusdoc I have 2 questions: 1. How does the 10v run on 1gig of ram? Necessary to upgrade? 2. I read something that Snow Leopard 10.6.2 has issues with the Atom Processor and that we shouldnt update to that, can youprovide any clarification on that? Articles Below Is Apple Trying to Kill Hackintosh Netbooks? OS X 10.6.2 Ditches Atom CPU Support - Snow Leopard Atom Support Hackintosh Netbook - Gizmodo Netbook Hackintosh 10.6.2 Fix Coming In "A Few Weeks," Fallen Netbooks Can Be Revived Now - 10.6.2 Hackintosh - Gizmodo Tick |
(#23)
1. My Snow Leopard install seems to run fine with 1 GB RAM. I think the processor and hard disk rpm are more significant drags on performance. No matter how much RAM you have, this won't be a gaming machine. 2. The 10.6.2 bug is fixed by the latest release of NetbookInstaller, 0.8.3 alpha. As long as you use that release, you'll be fine. I am running 10.6.2 now. -virusdoc | |
(#24)
| Junior Member Posts: 29 Join Date: Jan 2010 | VirusDoc, As always thanks for the clarification! ![]() This may have been asked already but if I get my hands on a MAC is it possible to do dual booting with Windows XP (which is what is coming on my 10v) or should I upgrade to Windows 7 and follow your guide? Thanks Again! -Tick |
(#25)
But I might be wrong and there may be some smart person who found a way around this. Try searching the "Dual Booting" forum here. EDIT: a quick google found this blog entry from a person who claims to have done this. Can't vouch for whether or not it works, and the entry is a bit dated: http://count-0.tumblr.com/post/26975...dows-on-a-dell | |
(#26)
| Junior Member Posts: 29 Join Date: Jan 2010 | VirusDoc, Thanks again for the quick turn around, if I go this route I am going to stick with your "Detailed" and tested approach... Once again Thanks!!! You Da'Man... ![]() ~Tick |
(#27)
More information here: XP and Snow Leopard and here: http://www.mydellmini.com/forum/gene...tml#post101685 Good luck! | |
(#28)
| Junior Member Posts: 16 Join Date: Jan 2010 | Any recommendations for USB drives that are known to be problem-free? I read some where sandisc cruzer ---------- Post added at 03:08 AM ---------- Previous post was at 03:08 AM ---------- Any recommendations for USB drives that are known to be problem-free? I read some where sandisc cruzer |
(#29)
| Senior Member Posts: 162 Join Date: Dec 2009 | sandisk cruzer will done her job perfect. i had used an 8gb sandisk cruzer |
(#30)
| Junior Member Posts: 1 Join Date: Feb 2010 | EVERYTHING WORKS!!!! FOLLOWED EXACTLY!!! (except I made two partitions) I have the nickelodeon version of the the 10v I didn't have to do anything but follow the steps... THANK YOU!!!! (after 10hrs and 6hrs of driving around houston to find the 10v and 10.6!!!!) -Andy |
n LEGACY
