Default 01-10-2010, 05:26 PM
can you use an 8gb usb stick then? why did you say (or larger) just checking before i cough up the dough
Default 01-12-2010, 02:50 AM
8 GB will work just fine!
-virusdoc
Default 01-13-2010, 03:31 AM
I am running into trouble when trying to get the mouse working again...
I ran Netbookinstaller and checked "Install Dell Mini 10v Extensions"
rebooted
There has been no change in mouse behavior, and no change in system preferences to allow additional settings.
I really need to be able to "tap-to-click" and I have to have the two finger scroll. :-)
  (#14) Old
Default Hackentosh Issues - 01-13-2010, 06:32 AM
OK - I have the 10v with A05 Bios... Not working soo simple for me. Not sure what I am missing. After I install the OSX, I get Operating System not found. I followed the instructions to a t and nothing... Please Help!
  (#15) Old
Default 01-16-2010, 01:45 AM
Originally Posted by Montala View Post
This is not my usual 'field', but I thought I read on here somewhere that there is a later version of NetBookMaker now available, which (naturally!) works fine with A06?
Edit: Or am I getting confused with Netbook Installer here?... I said I was a bit 'new' to this?
No, you're not confused. This guide is very outdated (despite being recently posted). Netbookmaker and Netbookinstaller (two sides of the same coin, really--one handles EFI booting for install, the other handles post-install netbook tweaking and driver installation) both work fine with A06 as of version 0.8.3 RC5, including the current 0.8.3 alpha release.
NO NEED TO DOWNGRADE YOUR BIOS!
---------- Post added at 08:41 PM ---------- Previous post was at 08:37 PM ----------
rebooted
If you are using NetBookInstaller 0.8.3 alpha (the latest release), you should have a "Trackpad" preferences pane that will allow you to enable tap-to-click and two finger scrolling.
---------- Post added at 08:45 PM ---------- Previous post was at 08:41 PM ----------
Follow my guide here:
Complete Guide to Dual Booting 10v with Windows 7 and OSX 10.6.2
and see if that helps!
(Note: this guide is for dual-booting with Windows 7. Just following the instructions for installing Snow Leopard, and instead of creating two partitions in Phase 3, just create one.)
  (#16) Old
Default Basic Question - 01-21-2010, 05:20 AM
Hey guys, first of all THANK YOU all for this I cant wait to get started, but i have i think a basic question.
1. If you do not have access to a MAC is there any other way to make the Flash Drive? Can I Use another Disk Utility for Windows Vista which is my Desktop is? What are some other option to making the Flash Drive?
By the way I did by an original install from Apple, $29bucks LOVE IT...
2. The NetbookBootMaker_0.8.3.app, is this to only run on MACs? same issue I think I need this to create my Flash Drive.
My only sticking point is creating this Flash Drive, any assistance would be MUCH appreciated...
Thanks in Advance
Tick!
  (#17) Old
Default 01-21-2010, 11:27 AM
Thanks in Advance
Tick!
As I mention above, this guide is really outdated. All of your questions are answered in the first section of my guide:
See the section entitled "A few warnings", number 3. And good luck!
(Note that you don't have to use my guide for dual booting--all the steps work fine to generate a single boot system. Just create only the first partition in Phase 3, step 5, and allow it to occupy the entire drive. Then complete the remainder of Phase 3 (installing Snow Leopard) and skip to Phase 7 for post-install tweaks).
-virusdoc
  (#18) Old
Montala's Avatar
Default 01-21-2010, 01:47 PM
-virusdoc
Hi Virusdoc,
I am also in a similar position, and am therefore interested in your reply.
When you say that "this guide is really outdated", are you refering to your own guide, to which you provided a link, this one by MaLiCiOuS, or to MechDrew's guide, which you link to in Number 3 of your 'A few warnings' section?
For anyone, like 'Tick' and myself, who do not have access to a Mac, (and are fairly new to all this!) are you now recommending that we follow your Guide, or MechDrews?
As I have said before, I am still learning about 'mackintoshing', but it is something I would like to try on my Mini 10v... (not dual-booting though), especially as I hope to have an iPhone shortly!
Thanks.
P.S. Welcome to the Forum, 'Tick!'
  (#19) Old
Default 01-21-2010, 02:00 PM
Hi Virusdoc,
Sorry for the unclear antecedent. The guide that is outdated is Malicious's guide, above. It was copied verbatim from a Gizmodo article last October. Huge improvements have been made to NetBookInstaller since then, streamlining the install process and eliminating the need to downgrade your BIOS. I noted this above, and I wish Malicious would return and either update the guide or at least post a warning about it being out of date.
My guide is current and I'm updating it regularly to keep it so:
Mechdrew's guide for making the Snow Leopard install USB with a PC is also current, and works well.
Good luck!
-virusdoc
  (#20) Old
Montala's Avatar
Default 01-21-2010, 02:41 PM
Thanks for a prompt and helpful reply Virusdoc.
As neither of us have access to Mac computers, just PC's, it looks as if we will therefore have to use MechDrews guide, rather than your excellent one!
Something to leave until I have a bit more time at the weekend though, I think!
« Hi!!!! I'm desperate | Installation of Snow Leopard on Mini 10v »
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/17087-how-hackintosh-dell-mini-10v-into-ultimate-snow-leopard-netbook.html
Posted By For Type Date
????? : ?????? snow leopard ??? EeePc 1101HA This thread Refback 10-06-2010 06:51 PM
joelkuehn's hackintosh Bookmarks on Delicious This thread Refback 10-05-2010 09:03 PM
DavilBlog - Tech Geek Stuff: March 2010 This thread Refback 09-30-2010 04:46 PM
bit.ly statistics for (How to Hackintosh a Dell Mini 10v into the ultimate Snow Leopard netbook) This thread Refback 08-31-2010 08:23 PM
iPad uit Amerika halen | One More Thing This thread Refback 08-15-2010 10:59 PM
Popular hackintosh Bookmarks on Delicious This thread Refback 07-05-2010 03:40 PM
hackintosh « Search Results « otherwise This thread Refback 07-04-2010 09:06 AM
breretc's apple Bookmarks on Delicious This thread Refback 06-18-2010 12:58 PM
Hackintosh 10v Trackpad | Lifedork This thread Refback 06-03-2010 02:27 PM
breretc's mac Bookmarks on Delicious This thread Refback 05-06-2010 01:02 PM
breretc's Bookmarks on Delicious This thread Refback 05-06-2010 11:53 AM
dirt's Bookmarks on Delicious This thread Refback 05-05-2010 12:48 AM
How to Hackintosh a Dell Mini 10v into the... - Nick Shue - FriendFeed This thread Refback 05-03-2010 10:46 PM
Pinboard: bookmarks for liedra This thread Refback 04-23-2010 03:51 PM
estiraven's Bookmarks on Delicious This thread Refback 04-14-2010 02:31 AM
iPad uit Amerika halen | One More Thing This thread Refback 04-03-2010 08:45 PM
Osx on ASUS EeePc 1101HA ? - InsanelyMac Forum This thread Refback 04-03-2010 04:57 PM
Mac OS X Snow Leopard 10.6.2 on Dell Mini 10v Guide This thread Refback 04-02-2010 07:24 AM
CWF's HackIntosh_UMPC Bookmarks on Delicious This thread Refback 03-30-2010 09:04 AM
2x (Two) Dell Mini 10v Netbooks: Intel Atom N280 1.66GHz, 1GB DDR2, 160GB HDD, WiFi G, Webcam, 10.1" (1024x600) Screen, Win XP Home, 3-Cell Battery $411 - Page 47 - SlickDeals.net Forums This thread Refback 03-25-2010 06:20 AM
2x (Two) Dell Mini 10v Netbooks: Intel Atom N280 1.66GHz, 1GB DDR2, 160GB HDD, WiFi G, Webcam, 10.1" (1024x600) Screen, Win XP Home, 3-Cell Battery $411 - Page 47 - SlickDeals.net Forums This thread Refback 03-24-2010 05:10 AM
lipbalm's osx Bookmarks on Delicious This thread Refback 03-22-2010 05:22 PM
?230 Intel Mac laptop? Fuck yeah! - Pattaya Forum This thread Refback 03-21-2010 10:43 AM
DavilBlog - Tech Geek Stuff: Making Apps for Phones using only web technologies This thread Refback 03-18-2010 01:57 PM
jaegermister's Bookmarks on Delicious This thread Refback 03-09-2010 11:25 PM
Vilken eeePC ska man välja ? - MacWorld - allt om Mac & iPhone - Sida 2 This thread Refback 02-24-2010 10:27 AM
Anyone here successfully put OS X on a Dell Mini 10v? - Computing and Networks - Digital Spy Forums This thread Refback 02-20-2010 12:53 AM
How to Hackintosh a Dell Mini 10v into the ultimate Snow Leopard netbook This thread Refback 02-12-2010 02:57 PM
MacBook for $279 ~ try a Hackintosh - Page 2 - The Gear Page This thread Refback 02-07-2010 12:38 PM
composizioni's Bookmarks on Delicious This thread Refback 01-31-2010 03:39 PM
How to Hackintosh a Dell Mini 10v into the ultimate Snow Leopard netbook This thread Refback 01-29-2010 12:21 AM
How to Hackintosh a Dell Mini 10v into the ultimate Snow Leopard netbook This thread Refback 01-27-2010 05:26 PM
madmaxmedia's hackintosh Bookmarks on Delicious This thread Refback 01-26-2010 11:03 PM
Anyone here successfully put OS X on a Dell Mini 10v? - Computing and Networks - Digital Spy Forums This thread Refback 01-26-2010 07:37 PM
MacKorisnik.com • Pogledaj temu - Netbook + OS X This thread Refback 01-26-2010 12:37 PM
Dell Mini 10 Guides This thread Refback 01-20-2010 01:26 PM
