(#11)
| Guru Posts: 1,744 Join Date: Sep 2008 Location: Olalla, WA | Yeah, found that. It's a KR.. Geeze.. |
(#12)
| Expert Member Posts: 521 Join Date: Nov 2008 Location: Dislocated | ok, part number C050H, the representative said me that they have 10 part number for the item (and none with KR or CN on them, theyre retarded!), so my CN one has these part number, C050H. anyone with another CN battery please post part number. |
(#13)
| Member Posts: 47 Join Date: Nov 2008 | Quote:
ie about this mac> more info >power it will give it in mah mine reads 2200mah (its a korea batt) just multiply 2200 to volt to get wh so the mini is 14.8v x 2.2 ah = 32.56wh | |
(#14)
| Expert Member Posts: 521 Join Date: Nov 2008 Location: Dislocated | the representative told me that the system choose "the best replacement" part number for the system. so i think that they will send us the same part number that the "wrong" one based in their shipment-order database. :? mine is on the way, lets see wat happen now ![]() almost two hours! again! :lol: ---------------------- WE NEED FEEDBACK post part number from your CN and KR batteries (is on the paper attached to the fedex box). this is serious bussines, many people has this problem so we need to know if at least is there a connection between bad batteries and part number, so we can request the correct batteries. when you talk to the representative of dell technical support, they may ask you for part numbers, service tags, etc, in my case helps a lot the pictures that i made (early post), so, made ones for yourself, or feel free to use mine as a proof. better to use it in the technical support chat off course ![]() CN "Good" Battery - part number: C050H |
(#15)
| Super Moderator Posts: 883 Join Date: Oct 2008 Location: FAA | http://accessories.us.dell.com/sna/prod ... 2#Overview So that would make above Mini battery D044H not higher capacity type? |
(#16)
| Junior Member Posts: 6 Join Date: Nov 2008 | This is mine (linux) root ~/tmp # cat /proc/acpi/battery/BAT1/info present: yes design capacity: 2200 mAh last full capacity: 2200 mAh battery technology: rechargeable design voltage: 11100 mV design capacity warning: 420 mAh design capacity low: 156 mAh capacity granularity 1: 264 mAh capacity granularity 2: 3780 mAh model number: serial number: 11 battery type: Lion OEM info: DELL ----- 11,100mV * 2,2Ah = 24,42Wh is this right ? so it is a 24Wh battery ? thanks. |
(#17)
| Expert Member Posts: 521 Join Date: Nov 2008 Location: Dislocated | Quote:
the answer is who knows, there are 10 part numbers for the battery item, according to the technical support representative, so that's why we need to do some sort of database ![]() there are few other part numbers in the part numer thread, but we don't know yet is they're good or not. ups, in the page says "Manufacturer Part# : D044H | Dell Part# : 312-0831", so, is a proof that any C050H will be a good one because is related to the manofacturer \o/ | |
(#18)
(#19)
(#20)
| Senior Member Posts: 138 Join Date: Nov 2008 Location: Bucks, UK | ![]() Got to check mine tonight too! That's just not on, is it? |
« Page File
BIOS 03 is released »
ops:
