(#141)
| Senior Member Posts: 118 Join Date: Oct 2008 Location: Baton Rouge LA | Quote:
(#142)
| Senior Member Posts: 100 Join Date: Dec 2008 | Quote:
(#143)
| Junior Member Posts: 15 Join Date: Nov 2008 | No need to lie. Just got off the chat with Dell and they quickly agreed to replace my KR tagged battery. I just reported that it showed 2200mAh under Ubuntu and after a few minutes they are sending me a new one. The only bug was she noted if the new battery didn't show a higher value I should update to the new BIOS. I reminded them of this thread and that to be sure I wouldn't get another defective battery and she indicated the request would be escalated. Time on chat: 10 minutes... Ubuntu Mini 9 purchased on 11/20.. Inspiron Mini 10v:Standard:2GB RAM:10.6.4 |
(#144)
| Senior Member Posts: 130 Join Date: Dec 2008 | Quote:
They haven't shoplifted anything, even if your battery has only 3 cells. Shoplifting, like all words, has a specific meaning and this isn't it. In any case, your battery almost certainly has precisely the correct number of cells in it, regardless of the reported capacity (try reading the OP's follow up). It may be that your battery is defective, but that is a) not shoplifting by Dell sales (or anyone else), b) not any other form of theft, c) not caused by the lack of a cell, and d) fixed by correctly and calmly reporting it to Dell support and getting it replaced. White Mini 9 2GB/4GB - UNR 9.10 | |
(#145)
| Junior Member Posts: 20 Join Date: Nov 2008 Location: Annapolis, MD, USA | Recieved my replacement battery from Dell today. It is also a 'KR' and actually looks used (maybe 'refurbished'). I'll do a real life test on both and return the poorer performing 'KR' battery. Live and learn.... ops: |
(#146)
| Junior Member Posts: 10 Join Date: Nov 2008 | how do i check my battery info in vista? |
(#147)
(#148)
| Junior Member Posts: 10 Join Date: Nov 2008 | i downloaded batterymon by passmark and its indicated i only have a 24420mWh battery too....time to yell at dell. |
(#149)
| Senior Member Posts: 118 Join Date: Oct 2008 Location: Baton Rouge LA | Have those of you who are still griping about the battery actually READ this thread? The person who started the hoorah posted time results that show the so-called "defective" battery lasting longer than the so-called "higher capacity" battery. Here's a link to that message that basically says, "Never mind!" http://www.mydellmini.com/forum/batt...10.html#p13788 Sheesh, people. This is not cause for hysteria. If it's a problem, there's ample time to get it corrected. It may simply be a problem with the way the software READS the battery info, not a problem with the battery itself. Anyone who believes that the battery will last exactly as long as Dell advertises is pretty naive. Cars don't get the advertised mileage, and the same car will get different mileage under different driving conditions. Your battery may last 3.5 hours one day and 5 hours the next, depending on what you are doing. |
(#150)
| Senior Member Posts: 135 Join Date: Sep 2008 Location: Yukon, OK, USA | Is there a way to see the 24 mWh in XP? I hate to tell them some other software is indicating I have a lesser battery. At least if I can see it in XP, they can't argue that the software is flawed. |
« Page File
BIOS 03 is released »
ops:
