Default Authentication Problem Failsafe Terminal - 10-05-2009, 03:22 PM
My machine info is an Inspiron 910 BIOS A04
Ubuntu 8.04.01
Problem: When I am in the failsafe terminal mode I don't have permission to do a thing. Leading up to getting to the failsafe terminal are the following messages.
Also, I can not boot into recovery mode no matter how or how many times I hit "Enter + Escape" real fast.
I want to learn from this, and try to salvage with the forums before reinstalling, please help.
Error messages
Your home directory is listed as:'/home/wagner' but does not appear to exist. Do you want to log in with the / (root) directory as your home directory? It is unless you use a failsafe terminal.
I click, Yes
User's $HOME/.dmrc file is being ignored. Thid prevents the default sesion and language from being saved...
I click OK
Now I,m at the terminal, wagner@mars:~$ and no matter what I type I get the error message,
>>> sudoers file: syntax error, line 26 <<<
sudo: parse error in /etc/sudoers near line 26
wagner@mars:~$ 2009-10-05 09:09:02 1MuoFK-0001KX-Ca Failed to create spoole file /var/spool/exim4/input//1MuoFK-0001KX-Ca-D: Permission denied. It repeates this message twice.
Please help. Thank you for you time.
Default 10-05-2009, 03:29 PM
Welcome to the forum, but please do not double-post. Closing this one - your original thread is Authentication Error
« Silverlight 2.0 and Dell MiniMac SOLVED | Making Mini Boot like a Mac? »
