(#21)
| Member Posts: 36 Join Date: Dec 2008 | Has anyone received their enclosure and got it to work? Trying mine with the original Dell Mini 9 STEC drive. When I try to initialize it in OSX, I receive the following error: "POSIX reports: The operation couldn't be completed. Input/output error." When I try to initialize it in Windows, I receive the error: "The operation could not be performed because of an I/O device error." |
(#22)
| Member Posts: 49 Join Date: Dec 2008 | Received mine today. Here is my breif review. Negative - Mine arrived in pieces with the circuit board sliding around inside the metal case with a bunch of little screws. I had to screw it down myslef. Not a big deal, but there is a chance in shipping that it could get badly scratched. The case was packed well in bubble wrap though. - After inserting the SSD I had to force it down pretty hard to get it to the srew holes. The SSD is actually almost arched. I was afraid I might snap it. - The USB is a mini USB so an included cable must be used. I would prefer something like a thumb drive. It is just another cable to loose. The cable is a mini USB to two standard USB, although only one is required to function. Positive + The case is a strong heavy duty metal, so it will be sturdy. + The drive seems to be fast, although I have not run and speed tests on it yet. + Simple assembly, and plug and play. Windows 7 installed without issue, no drivers needed. + Good use for an old drive for you may have sitting around. As I use it more and run a few speed tests, I will update my review. Would I recommend it? Absolutely! For $20 you can't go wrong. ---------- Post added at 11:21 PM ---------- Previous post was at 11:18 PM ---------- Quote:
(#23)
| Member Posts: 49 Join Date: Dec 2008 | Here is the benchmark for the stock SSD running in the USB enclosure. I ran HD Tune under Windows 7 RC7100. |
(#24)
| Member Posts: 36 Join Date: Dec 2008 | Mine was preformatted as well, but the drive shows as uninitialized when plugged in. I think I may have received a defective unit. |
(#25)
| Super Moderator Posts: 1,203 Join Date: Apr 2009 Location: Detroit | Hopefully I'll get mine today and can test. Triple Boot Guide - 10v RAM Upgrade Videos - mechdrew's OSX guides |
(#26)
| Member Posts: 49 Join Date: Dec 2008 | I tried booting from it, since you can boot from USB storage, however Windows XP gave me the BSOD. Windows XP boots correctly when the drive is in the Mini, just not in the external enclosure. Not sure if I am doing something incorrect to get it to boot from USB though. |
(#27)
(#28)
| Super Moderator Posts: 1,203 Join Date: Apr 2009 Location: Detroit | Just got my case, so far everything seems to work great. Very heavy duty case. My only gripe is with the screws. SSD went in with no problem though. So far, well worth it. Triple Boot Guide - 10v RAM Upgrade Videos - mechdrew's OSX guides |
(#29)
| Junior Member Posts: 24 Join Date: Mar 2009 | Just a quick update on the External enclosures.. The holes for the 50MM SSD's are a bit tricky (even more so if you were using a 70mm SSD). I've found that tightening each screw just enough to get them both started and then completely tightening them works quite well. As for booting from the external enclosure, Holmes4 is correct. Windows does not like booting from an external at all. You'd have more luck with a linux install on the external. Hope this helps out a bit! |
(#30)
| Super Moderator Posts: 1,203 Join Date: Apr 2009 Location: Detroit | Quote:
Triple Boot Guide - 10v RAM Upgrade Videos - mechdrew's OSX guides | |
« PLEASE HELP: 10 OS X Snow Leopard on Mini 10v
*OBSOLETE* NetbookInstaller .8.3 Release Candidate 1 [testing] »
