(#61)
(#62)
| Senior Member Posts: 130 Join Date: Feb 2009 Location: Rome, Italy | audio is working without installing any additional kexts? because I still haven't audio also after permissions fixing. |
(#63)
(#64)
| Senior Member Posts: 201 Join Date: Aug 2009 | Quote:
the touchpad is as flaky as before - hthNope! seems fine here | |
(#65)
| Junior Member Posts: 2 Join Date: Sep 2009 | I have the same problem. Everything works, WiFi, Ethernet but not the audio. One exception to the install instructions in the 1st post is that I had to do the fix the permissions on the Extra directory and use mkext before I could get it to boot off the flash drive. |
(#66)
| Junior Member Posts: 3 Join Date: Aug 2009 | Can I "restore" the SL DVD to an SD card instead of a USB drive? In other words, I don't have a USB drive, but I do have an 8GB SDHC card and am wondering if I can use that on my 10v to do the installation from. Thanks in advance... |
(#67)
| Member Posts: 64 Join Date: Aug 2009 | Quote:
Reason I'm posting this is that I have the A06 bios, not sure if anyone cares, or if it makes any difference. Just FYI.. Thanks for the permissions explanation, I will try those once it boots up (IF it boots up, meaning, without a kernel panic). | |
(#68)
| Junior Member Posts: 7 Join Date: Jul 2009 | Yes you can, Just make sure you partition as a grub |
(#69)
| Senior Member Posts: 130 Join Date: Feb 2009 Location: Rome, Italy | |
(#70)
| Member Posts: 53 Join Date: Mar 2009 | worked perfectly for me. THANKS! |
| Tags |
| meklort, nbi, nbm, netbookbootmaker, netbookinstaller, official, snow leopard |
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/12338-official-snow-leopard-mini-netbookbootmaker-method-old-method.html | ||||
| NetbookInstaller Update Meklort's Blog | This thread | Pingback | 09-04-2009 04:25 AM | |
| **OFFICIAL** Snow Leopard on the Mini (NetbookBootMaker Method) | This thread | Refback | 09-04-2009 01:17 AM | |
| Forum de la communauté Zimbra francophone / Zimbra Desktop | This thread | Refback | 09-03-2009 05:32 PM | |
| Snow Leopard Pre Order | RK.md | This thread | Refback | 09-03-2009 02:56 AM | |
| cacophony's Bookmarks on Delicious | This thread | Refback | 09-03-2009 02:39 AM | |
| Recent mac Bookmarks on Delicious | This thread | Refback | 09-03-2009 12:38 AM | |
| Lenovo IdeaPad S Series Forum • View topic - Partial Guide to Snow Leopard on S10 | This thread | Refback | 09-02-2009 09:36 PM | |
| Lenovo IdeaPad S Series Forum • View topic - Snow Leopard install on S10 using ext. DVD drive ?? | This thread | Refback | 09-02-2009 11:57 AM | |
