(#641)
| Junior Member Posts: 13 Join Date: Aug 2009 | So....before i rebuild my system from scratch using the new Netbootmaker and SL DVD, is there some sound drivers i should try? My current problem was posted last night --- http://www.mydellmini.com/forum/os-x...html#post99366 Thanks for any suggestions. |
(#642)
| Junior Member Posts: 16 Join Date: Mar 2009 | Am I correct in assuming that on the Dell Mini 9 that sleep does not work with STEC but does work with RunCore? |
(#643)
| Member Posts: 62 Join Date: Oct 2008 | Quote:
EDIT: Sleep does not.....well actually there's a shortcut and it does go to sleep, but when it wakes up there's no response from the system | |
(#644)
| Junior Member Posts: 27 Join Date: Mar 2009 | anyone else having trouble with wpa2 enterprise? my mini 9 (2gb, 64gb runcore) is running with 10.6, but I have been having trouble with wpa2 enterprise authentication on wireless. my wireless network is fine and this worked with my previous 10.5.6 install. |
(#645)
| Member Posts: 62 Join Date: Oct 2008 | Can anyone point out how to enable audio on the Mini 9? The steps above for some reason do not work for me as the IOAudioFamily.kext file from System/Library/BackupExtensions does not exist (no files exist in that folder).....even after I've enable the show hidden files feature. HELP! |
(#646)
| Junior Member Posts: 16 Join Date: Mar 2009 | I have this too. It wakes, but nothing works - spinning beachball. If I have a terminal open and try and do things - even ls I get the 'operation not allowed'. It's like the STEC is not coming out of sleep. |
(#647)
| Member Posts: 69 Join Date: Mar 2009 Location: PA, USA | Quote:
MS ![]() Apple iMac i7 - The beast in a suit ![]() -- 2x Mini 9 - Obsidian Black - 2 GB RAM - 16 GB STEC SSD - OS X.6.5 - NBI 0.8.4RC2 (??) 1x Mini 10v - Obsidian Black - 2Gb RAM - 160gb hdd - A06 OS X.6.6 - NBI 0.8.5pre - Everything enabled | |
(#648)
| Member Posts: 36 Join Date: Apr 2009 | After following this thread and updating constantly I am still unable to get a usable 10.6 install. Now Time Machine does not work. It seems to make the backup but crashes when I try to enter Time Machine. Also sometimes the system slows to a crawl and becomes unusable. I must go back to 10.5.8. It worked fine. I would gladly accept the sound problem now if I could get the rest of it to work. |
(#649)
| Senior Member Posts: 143 Join Date: Mar 2009 | Quote:
(#650)
| Member Posts: 69 Join Date: Mar 2009 Location: PA, USA | USE only if the real kext is missing... S/L/E or S/L/BE The missing IOAudioFamily.kext (???) is attached. MS ![]() Apple iMac i7 - The beast in a suit ![]() -- 2x Mini 9 - Obsidian Black - 2 GB RAM - 16 GB STEC SSD - OS X.6.5 - NBI 0.8.4RC2 (??) 1x Mini 10v - Obsidian Black - 2Gb RAM - 160gb hdd - A06 OS X.6.6 - NBI 0.8.5pre - Everything enabled |
| Tags |
| meklort, nbi, nbm, netbookbootmaker, netbookinstaller, official, snow leopard |
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/12338-official-snow-leopard-mini-netbookbootmaker-method-old-method.html | ||||
| NetbookInstaller Update Meklort's Blog | This thread | Pingback | 09-04-2009 04:25 AM | |
| **OFFICIAL** Snow Leopard on the Mini (NetbookBootMaker Method) | This thread | Refback | 09-04-2009 01:17 AM | |
| Forum de la communauté Zimbra francophone / Zimbra Desktop | This thread | Refback | 09-03-2009 05:32 PM | |
| Snow Leopard Pre Order | RK.md | This thread | Refback | 09-03-2009 02:56 AM | |
| cacophony's Bookmarks on Delicious | This thread | Refback | 09-03-2009 02:39 AM | |
| Recent mac Bookmarks on Delicious | This thread | Refback | 09-03-2009 12:38 AM | |
| Lenovo IdeaPad S Series Forum • View topic - Partial Guide to Snow Leopard on S10 | This thread | Refback | 09-02-2009 09:36 PM | |
| Lenovo IdeaPad S Series Forum • View topic - Snow Leopard install on S10 using ext. DVD drive ?? | This thread | Refback | 09-02-2009 11:57 AM | |
