  (#501) Old
Default 09-07-2009, 05:28 AM
Hello
I am new here
I installed snow leopard successfully on my mini 9 . Every thing seem to work fine except for the sound no sound from built in speaker and headphone . the good thing that I have USB headphone and it work very well but I still need the built in speaker and mic.
Thank you guys for your help.
  (#502) Old
Default Service Battery? - 09-07-2009, 05:32 AM
I just did a clean install of 10.6, and everything is so much more responsive. I used to get hangs launching mail or safari, but now they just pop onto the screen.
However, I'm getting a service battery warning in the power menu bar item, and I don't know what to make of it. I've also noticed that the time it says I have left at 100% has dropped by about half an hour since 10.5.7. It used to say 4 hours, but now says 3.5.
So, does my battery really need service? I kind of doubt it.
Red Mini 9 - 2 GB Mushkin RAM, 32 GB Super Talent, 1.3 MP Camera,
Snow Leopard 10.6
Inspiron E1505 1.6 Ghz Core Duo, 1 GB RAM, Intel GMA 950, 80 GB HDD, Leopard 10.5.8
Help me with Dropbox, please: https://www.getdropbox.com/referrals/NTE2ODgzMzE5
  (#503) Old
meklort's Avatar
Default 09-07-2009, 05:44 AM
Nope, just a bug in the battery kext. If you looked in system profile on 10.5, it would have said the battery condition was bad too, it just didn't tell you normally.
I'll look into fixing it on tuesday.
  (#504) Old
Default 09-07-2009, 05:59 AM
Thank you, its not said enough. Thank you!
Dell Mini 9 | Mac OS X 10.6.1 | BIOS A05 | 2 GB RAM | 16 GB RunCore SSD | NetBookMaker/Installer
1.66GHz Intel Core Duo Mac Mini | Mac OS X 10.6.1 | 2 GB RAM | 60 GB HDD | 1 TB External Storage Drive
1.33GHz PPC G4 | Mac OS X 10.4.11 | 1.5 GB RAM | 40 GB HDD
Get Dropbox
  (#505) Old
Default 09-07-2009, 06:43 AM
hey all,
im trying to install sl and running into a bump in the road. after preparing USB drive, i boot to it and it just sits on a blank screen with a blinking underscore in the top left corner. any ideas?
THanks in advance,
dan
  (#506) Old
circazero's Avatar
Default 09-07-2009, 07:02 AM
Originally Posted by dew912 View Post
hey all,
THanks in advance,
dan
how are you booting up?
do you have USB Legacy support enabled?
are you selecting USB device to boot from?
Dell Mini 9 | OS X 10.6.1 | 64GB SSD | 2GB RAM | 32GB SDHC
BIOS A05 | USB Legacy Support: Disabled | NBI 0.8.3 RC3
MacBook Pro 15" | OS X 10.6 | 2.66GHz | 120GB SSD | 4GB RAM
  (#507) Old
Default 09-07-2009, 07:07 AM
Originally Posted by agsss View Post
FAkio87, I installed snow leopard on my mini 9 with an 8gb ssd. if you go to mechdrews site, he has an advanced tutorial about customizing the installer. following that tutorial allowed me to disable the speech voices and the dictionaries in the section where you customize your install. that made it fit just fine. as we speak, i have 3.65 gb free.
Thank you for that information
i followed the tutorial but After replacing the old file with the new one and starting the netbookinstaller to get a bootable stick the mini does try to install by Network. I saw this Problem when i tried to install a corrupt/damaged version of Arch Linux on my dell mini 9.
Any ideas how to solve this issue?
Thank you for your help so far!
Fakio
  (#508) Old
Default 09-07-2009, 07:08 AM
hey,
usb legacy is enabled.
i have actually tried disabling all others just in case.
i prepared the usb as follows. made the dvd into a dmg file. erased and reformat as osx journaled extended. restored the dmg file. ran nbm from the link on the first page. plugged into USB on left (also tried right side). no luck.
Thanks for your help!
-Dan
  (#509) Old
circazero's Avatar
Default 09-07-2009, 08:10 AM
hey,
-Dan
what boot order are your settings in?
regardless, when you turn on your mini and see the dell logo hit 0 (zero).
then select USB Device to boot from.
you should be booting up. at least you should get into the apple logo. if it freezes there we can also see what the problems is by doing -v
  (#510) Old
Default 09-07-2009, 09:59 AM
thanks for the response - it turns out i did not set up the partition scheme correctly when i transferred the image of hte dvd over to my usb drive. hope this helps if anyone else runs into the same problem. now i got to figure out why EasyBCD won't boot into either snow leopard or win7. gong to repair windows using install DVD (on USB) and re-install EasyBCD - unless anyone has any other ideas...
meklort, nbi, nbm, netbookbootmaker, netbookinstaller, official, snow leopard
« Bootloader brain damage? | NetbookInstaller 1: USB Installation via Mac »
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/12338-official-snow-leopard-mini-netbookbootmaker-method-old-method.html
Posted By For Type Date
NetbookInstaller Update Meklort's Blog This thread Pingback 09-04-2009 05:25 AM
**OFFICIAL** Snow Leopard on the Mini (NetbookBootMaker Method) This thread Refback 09-04-2009 02:17 AM
Forum de la communauté Zimbra francophone / Zimbra Desktop This thread Refback 09-03-2009 06:32 PM
Snow Leopard Pre Order | RK.md This thread Refback 09-03-2009 03:56 AM
cacophony's Bookmarks on Delicious This thread Refback 09-03-2009 03:39 AM
Recent mac Bookmarks on Delicious This thread Refback 09-03-2009 01:38 AM
Lenovo IdeaPad S Series Forum • View topic - Partial Guide to Snow Leopard on S10 This thread Refback 09-02-2009 10:36 PM
Lenovo IdeaPad S Series Forum • View topic - Snow Leopard install on S10 using ext. DVD drive ?? This thread Refback 09-02-2009 12:57 PM
