(#41)
| Super Moderator Posts: 1,420 Join Date: Mar 2009 Location: United States | Follow the steps detailed in the first post. The NetbookBootMaker should handle all of the patching during the installation... if you feel more comfortable by installing and then rebooting into the install DVD and running NetbookInstaller from the Utilities, then be my guest (it is just redundant and not necessary since it will do the same thing that NetbookBootMaker does during the install process as a postinstall AFAIK) Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides |
(#42)
| Junior Member Posts: 11 Join Date: Jul 2009 | Will donate! Restoring image now. 1 hour, 50 minutes to go ![]() |
(#43)
| Junior Member Posts: 2 Join Date: Jul 2009 | Quote:
(#44)
| Junior Member Posts: 6 Join Date: Jul 2009 | Ok. After install i seem to be where the OP says i should be. Everything seems to be working great save the Audio (which it recognizes, but doesn't let you do anything with...) and the sleep (which if you attempt to sleep...you will have to reboot to get out of the black screen you arrive in. Graphics seems to be fully accelerated, it sees my full Proc (though obviously doesn't call it Atom), Ram, and HD. Now to wait for someone to figure out why Audio and Sleep are borked. |
(#45)
| Super Moderator Posts: 1,420 Join Date: Mar 2009 Location: United States | Making progress ![]() Step-by-step Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides |
(#46)
| Guru Posts: 1,353 Join Date: Feb 2009 Location: Colorado, USA | Quote:
Could someone send me and output of NetbookBootMaker (in console.app) so I can see what's happening differently on my machine vs everyone elses. I should still be able to fix it w/o the output and i'll look into it tonight. Dell Mini 10v | Mac OS X 10.6.5 | 1 GB RAM | 160 GB HDD | BIOS A06 My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a Lockerz.com invite? message me. | |
(#47)
| Senior Member Posts: 201 Join Date: Aug 2009 | Just some feedback while I continue testing. I did an upgrade after creating the Extension.kext & all booted fine. I have sound, though at the mo it's stuttering like it did on the initial install on 10.5.8 so just need to figure out how to re-patch the sound.. well of to test further. Thanks again |
(#48)
| Senior Member Posts: 143 Join Date: Mar 2009 | Quote:
I got through the installer and have an account created. Almost to the desktop... will give feedback in a minute. | |
(#49)
| Senior Member Posts: 130 Join Date: Feb 2009 Location: Rome, Italy | ok, it's installed. what works: wifi, battery recognition what doesn't work: sleep, restart, webcam, sd recognition and audio |
(#50)
| Tags |
| meklort, nbi, nbm, netbookbootmaker, netbookinstaller, official, snow leopard |
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/12338-official-snow-leopard-mini-netbookbootmaker-method-old-method.html | ||||
| NetbookInstaller Update Meklort's Blog | This thread | Pingback | 09-04-2009 04:25 AM | |
| **OFFICIAL** Snow Leopard on the Mini (NetbookBootMaker Method) | This thread | Refback | 09-04-2009 01:17 AM | |
| Forum de la communauté Zimbra francophone / Zimbra Desktop | This thread | Refback | 09-03-2009 05:32 PM | |
| Snow Leopard Pre Order | RK.md | This thread | Refback | 09-03-2009 02:56 AM | |
| cacophony's Bookmarks on Delicious | This thread | Refback | 09-03-2009 02:39 AM | |
| Recent mac Bookmarks on Delicious | This thread | Refback | 09-03-2009 12:38 AM | |
| Lenovo IdeaPad S Series Forum • View topic - Partial Guide to Snow Leopard on S10 | This thread | Refback | 09-02-2009 09:36 PM | |
| Lenovo IdeaPad S Series Forum • View topic - Snow Leopard install on S10 using ext. DVD drive ?? | This thread | Refback | 09-02-2009 11:57 AM | |
