  (#31) Old
jaraeez's Avatar
Default 09-02-2009, 02:40 PM
Exact same issues as others with regards to kernel panic. Also doing the same steps though to a 8GB USB, then running the NBM. Then on the 10v booting from the USB & boom KP with same errors as others are reporting. This is a full retail disk I'm using if that helps.
  (#32) Old
Send a message via AIM to Carlos Send a message via Yahoo to Carlos
Default 09-02-2009, 02:56 PM
I installed the new NetBookMaker on my 10.6 installer USB stick. Kernel panic booting the installer.
The appleintelcpupower management kext is causing the kernel panic.
I think the permissions on the GeneralExtensions folder are funky.
Permissions:
system: Custom
wheel: Custom
everyone: Custom
  (#33) Old
Default 09-02-2009, 03:10 PM
Permissions:
system: Custom
wheel: Custom
everyone: Custom
I figured it out. An extensions.kext file was not installed by netbookmaker. So I ran MKextTool, created one and dropped it in the /Extra folder on the 10.6 Installer.
  (#34) Old
jaraeez's Avatar
Default 09-02-2009, 03:45 PM
OK & which kext(s) did you use to create it?
  (#35) Old
Default 09-02-2009, 04:15 PM
Can you patch netbookmaker with the correct kext that worked? does that mean you have it running and everything works?
  (#36) Old
bmcclure937's Avatar
Default 09-02-2009, 04:43 PM
I know it is hard, but have patience. Meklort will have an updated version ASAP. This thread is strictly following his releases at this point. It is great if other members have the gumption to experiment and find out what may be broken... then those fixes could be incorporated into NBM/NBI by meklort.
But, this thread should remain focused on the "official" method and try not to deviate (by posting modified versions of NBM). If you want to post modified versions, do it within the developers subforum or the respective OSX Snow Leopard subforum (this thread)
  (#37) Old
Default 09-02-2009, 04:47 PM
Carlos is right.
To fix it, you don't need to modify anything. Open your SL install image and go to the /extras folder. You'll see a folder there called GeneralExtensions. If you try and open it, you'll fail. Copy it to your desktop, right click, get info. Click the lock in the bottom right and authenticate. Change all the permissions to the folder to read/write. Open the folder and drop those Kexts into mkexttool and then drop the extensions.mkext it yields into your /extra folder on the SL disk. I'm presently in the installer, will post as to how it goes.
  (#38) Old
Default 09-02-2009, 05:04 PM
it's booting...
Dell Mini 9 Black with Bluetooth and Webcam - 32GB Super Talent - 2GB RAM
  (#39) Old
jaraeez's Avatar
Default 09-02-2009, 05:06 PM
Originally Posted by Zenji12 View Post
Carlos is right.
Cheers for that much appreciated. I know I should be patient but I'm itching - anyway installing now
  (#40) Old
Default 09-02-2009, 05:11 PM
should I run the NBI included in the utilities menu after the installation?
meklort, nbi, nbm, netbookbootmaker, netbookinstaller, official, snow leopard
« Bootloader brain damage? | NetbookInstaller 1: USB Installation via Mac »
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/12338-official-snow-leopard-mini-netbookbootmaker-method-old-method.html
Posted By For Type Date
NetbookInstaller Update Meklort's Blog This thread Pingback 09-04-2009 04:25 AM
**OFFICIAL** Snow Leopard on the Mini (NetbookBootMaker Method) This thread Refback 09-04-2009 01:17 AM
Forum de la communauté Zimbra francophone / Zimbra Desktop This thread Refback 09-03-2009 05:32 PM
Snow Leopard Pre Order | RK.md This thread Refback 09-03-2009 02:56 AM
cacophony's Bookmarks on Delicious This thread Refback 09-03-2009 02:39 AM
Recent mac Bookmarks on Delicious This thread Refback 09-03-2009 12:38 AM
Lenovo IdeaPad S Series Forum • View topic - Partial Guide to Snow Leopard on S10 This thread Refback 09-02-2009 09:36 PM
Lenovo IdeaPad S Series Forum • View topic - Snow Leopard install on S10 using ext. DVD drive ?? This thread Refback 09-02-2009 11:57 AM
