  (#221) Old
Default 09-04-2009, 06:34 AM
Originally Posted by meklort View Post
QE was working fine for me, although now it seams like it isn't. I'll take a look and see what I did to break it / what needs to be done to fix it.
EDIT:
Looks like it's a permission issue (like some people noted). I'll fix NetbookInstaller / NetbookBootMaker so that the permissions are set correctly.
EDIT2: should be fixed (same link as before). Let me know if it works.
it works. I can see the top sites now. This also seemed to fix the drive icons appearing as folders (or i had one of those lucky reboots). Good job Meklort.
  (#222) Old
Default 09-04-2009, 06:41 AM
Has anyone done a fresh install straight onto an 8GB internal SSD? Is SL slim enough if I unclick enough options? Tell me how you did it. Or does it still need 16GB.
  (#223) Old
Send a message via AIM to iwasakabukiman
Default 09-04-2009, 06:43 AM
When I run the NetbookInstaller.app it freezes and then crashes as soon as I enter the administrator password. Anyone else experiencing this problem? Any solutions?
Dell Mini 10v | Obsidian Black | 2 GB of RAM | 500 GB Samsung Spinpoint HDD | Mac OS X 10.6.1 Snow Leopard
  (#224) Old
Default 09-04-2009, 06:45 AM
Originally Posted by anthony415 View Post
Anyone test SMB on it?
NetbookInstaller Download Link [9/4/09 - 12AM EST]
that fixed it
  (#225) Old
Default 09-04-2009, 06:48 AM
hey yall no sl is not small enough to install straight on a 8gb drive i had to put it onto my external and then CLONED it straight over there was plenty of space
reason it wont go is all the temp room that it needs when installing!!
  (#226) Old
Default 09-04-2009, 06:49 AM
yeah make sure you have the most up to date version
  (#227) Old
Default 09-04-2009, 07:02 AM
it installed easily for me, no sound though, but i can wait
what i can't wait for is sleep, and i got it to work temporarily
i installed SleepEnabler.kext.zip from this thread
http://www.mydellmini.com/forum/95753-post53.html
i then had to disable bluetooth in the bios, just like i had to do in 10.5.8 to get sleep to work
the problem is that every time the computer is restarted, it resets the bios settings and the bluetooth gets turned back on, disabling my ability to sleep (i notice my boot order changes as well)
is NetBootMaker resetting my bios settings every time? can this be stopped?
better yet, can the bluetooth/sleep issue be resolved?
thanks to everyone who is helping out on this, it is truly a colossal effort
  (#228) Old
I have the most up to date version. I used the one I downloaded from the first post in this thread- I got it after the update was posted.
  (#229) Old
Default 09-04-2009, 07:09 AM
i would suggest deleting it and then re downloading it. that worked for me
  (#230) Old
Default 09-04-2009, 07:12 AM
Successfully installed on DellMini 9
Seems the graphics driver doesn't works for me. at least not full power support. For example, when I open a Finder, it can 'preview' some image files, while I open it with preview.app it cannot be displayed. If I expand the side bar of the preview.app it can have thumbnail, but the main preview won't work.
Also, easy to check, go to Time Zone Config, my SL cannot render the world map here (I still can click !! )
Anyway GREAT JOB, and keep working.
meklort, nbi, nbm, netbookbootmaker, netbookinstaller, official, snow leopard
« Bootloader brain damage? | NetbookInstaller 1: USB Installation via Mac »
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/12338-official-snow-leopard-mini-netbookbootmaker-method-old-method.html
Posted By For Type Date
NetbookInstaller Update Meklort's Blog This thread Pingback 09-04-2009 04:25 AM
**OFFICIAL** Snow Leopard on the Mini (NetbookBootMaker Method) This thread Refback 09-04-2009 01:17 AM
Forum de la communauté Zimbra francophone / Zimbra Desktop This thread Refback 09-03-2009 05:32 PM
Snow Leopard Pre Order | RK.md This thread Refback 09-03-2009 02:56 AM
cacophony's Bookmarks on Delicious This thread Refback 09-03-2009 02:39 AM
Recent mac Bookmarks on Delicious This thread Refback 09-03-2009 12:38 AM
Lenovo IdeaPad S Series Forum • View topic - Partial Guide to Snow Leopard on S10 This thread Refback 09-02-2009 09:36 PM
Lenovo IdeaPad S Series Forum • View topic - Snow Leopard install on S10 using ext. DVD drive ?? This thread Refback 09-02-2009 11:57 AM
