  (#201) Old
Default 09-04-2009, 03:18 AM
Originally Posted by ocean223 View Post
So I have to patch the OSInstall package then? How would I do that?
Look in the OS X guides for dual boot setups. XP requires MBR partitioning and Win 7 and Vista are easier to do with MBR although they can use GUD. Its just removing a simple script file the OS X installer runs to determine the type of partitioning. If I remembered what the file was I wouldn't tell you to search but I don't remember.
Dropbox Referral
  (#202) Old
Default 09-04-2009, 03:22 AM
Pollok, what do you mean by repair permissions ? are there files that are owned by root that shouldn't be ?
  (#203) Old
Talking I may have to wait this out-- - 09-04-2009, 03:24 AM
Thanks for all the hard work to everybody.
I tried repairing permissions. Finally got it to run installer but I guess I have to patch the OSInstall package to install on an MBR partition. Don't know how to do that so I'll wait it out.
Everything has worked so far (since around March) I'm happy with my 10.5.8 install. It works well.
Will keep watching.........
  (#204) Old
meklort's Avatar
Default 09-04-2009, 03:29 AM
Originally Posted by jaraeez View Post
Does anyone know if I would be ok to run the NBI from NetbookBootMaker.app 0.8.2 RC4 on a SL install to get the bootloader back without messing anything up?
Nope, wont work. It'll crash before the screen pops up and even if you could, I'd install the wrong bootloader.
I've just fixed the NetbookInstaller crash bug, so I'll look into sleep / restart real quick and let everyone know when I update the download (30 - 60 minutes).
  (#205) Old
Default 09-04-2009, 03:30 AM
In Disk Utilities, select the SL partition and hit the repair permissions button towards the bottom. I don't know exactly why things get hosed up, but they seem to do and by repairing them the OS sets permissions back to were the OS needs them in terms of read/write permissions. Maybe some of the Mac Technophiles can provide a more detailed explanation but most of my experience is on a PC.
When I did it, it repaired what seemed to be about 100 or so file permissions and a lot of them were kext files (basically drivers) so things that weren't working started.
Good luck.
  (#206) Old
jonoboyer's Avatar
Send a message via AIM to jonoboyer
Default 09-04-2009, 03:31 AM
Originally Posted by jonoboyer View Post
can someone please elaborate on how to copy the SL image to a flash drive in windows... i know its a noob question but i cant figure out what software i need to use to accomplish this..
i think i found a program called TransMac that will copy the snow leopard dvd to a usb stick on a windows computer...
creating image now!
well see how it goes!
  (#207) Old
Default 09-04-2009, 03:32 AM
You rock! Not sure I can stand another 30 to 60 minutes of the blue carpet of Boise State, but either way, thanks for all your work.
When you update NBI, you just rerun it and patch your installed OS....right?
  (#208) Old
jonoboyer's Avatar
Default 09-04-2009, 03:34 AM
now for the real question... how can i patch my SL usb drive from windows? is this at all possible, theres no way to run netbookmaker in windows is there?
  (#209) Old
jaraeez's Avatar
Default 09-04-2009, 03:47 AM
Cheers for the feed back. Just for the record I eventually managed to get it installed (phew!) by following this guide How to Build a Hackintosh with Snow Leopard, Start to Finish - Feature - Lifehacker
  (#210) Old
Default 09-04-2009, 03:48 AM
Pollok, Thanks so much!!! that repair did the trick, the camera now works and the live update works too!
meklort, nbi, nbm, netbookbootmaker, netbookinstaller, official, snow leopard
« Bootloader brain damage? | NetbookInstaller 1: USB Installation via Mac »
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/12338-official-snow-leopard-mini-netbookbootmaker-method-old-method.html
Posted By For Type Date
NetbookInstaller Update Meklort's Blog This thread Pingback 09-04-2009 04:25 AM
**OFFICIAL** Snow Leopard on the Mini (NetbookBootMaker Method) This thread Refback 09-04-2009 01:17 AM
Forum de la communauté Zimbra francophone / Zimbra Desktop This thread Refback 09-03-2009 05:32 PM
Snow Leopard Pre Order | RK.md This thread Refback 09-03-2009 02:56 AM
cacophony's Bookmarks on Delicious This thread Refback 09-03-2009 02:39 AM
Recent mac Bookmarks on Delicious This thread Refback 09-03-2009 12:38 AM
Lenovo IdeaPad S Series Forum • View topic - Partial Guide to Snow Leopard on S10 This thread Refback 09-02-2009 09:36 PM
Lenovo IdeaPad S Series Forum • View topic - Snow Leopard install on S10 using ext. DVD drive ?? This thread Refback 09-02-2009 11:57 AM
