(#101)
(#102)
| Junior Member Posts: 28 Join Date: Mar 2009 | This is a complete noob question but how do i get to the /extras folder, I can do the rest fine but im sorta new to osx and don't know all the features. |
(#103)
| Guru Posts: 1,353 Join Date: Feb 2009 Location: Colorado, USA | Quote:
That should fix the ramdisk errors (you wont have to do this once installed) In finder, it's go -> Go to folder -> type in /Extra Dell Mini 10v | Mac OS X 10.6.5 | 1 GB RAM | 160 GB HDD | BIOS A06 My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a Lockerz.com invite? message me. | |
(#104)
| Junior Member Posts: 26 Join Date: Jul 2009 | Quote:
but between already owning a compatible external DVD drive and having my RunCore on pre-order, I'll venture by the time the RunCore actually arrives you both will have something in place. ![]() Very kindly, keep up the great work, and don't forget to actually take a real break over Labor Day weekend! | |
(#105)
| Guru Posts: 1,353 Join Date: Feb 2009 Location: Colorado, USA | I'll probably take a day off for labor day, but I also get tuesday off so I'll definitely be working on it then. Dell Mini 10v | Mac OS X 10.6.5 | 1 GB RAM | 160 GB HDD | BIOS A06 My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a Lockerz.com invite? message me. |
(#106)
| Junior Member Posts: 6 Join Date: Jul 2009 | Mount the SL disk, and open it so you're looking at the Snow Leopard image and the installer and then Command, Shift, G. You can set what those keys are in the Keyboard pref pane if you're unsure of what your version of those keys are (or you can experiment). After that add "/Extra" to the path. You should be good. |
(#107)
| Junior Member Posts: 29 Join Date: Feb 2009 | Install worked perfect. Repaired permissions but still no sound. In the extra folder should it be called extensions or does it matter? 64GB SSD, 2GB RAM, 1.3mp Cam, BT Module OS X 10.5.6 |
(#108)
| Guru Posts: 1,353 Join Date: Feb 2009 Location: Colorado, USA | The one directory we *don't* use is /Extra/Extensions as chameleon will try to load extensions there if it can. The /Extra/Extensions.mkext file includes any extensions in /Extra/Mini10vExt / Mini9Ext or GeneralExtensions as well as any dependencies from /S/L/E. When the dependencies aren't included, bad things happen (kexts don't load), so we only let chameleon load /E/Extenisons.mkext. Dell Mini 10v | Mac OS X 10.6.5 | 1 GB RAM | 160 GB HDD | BIOS A06 My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a Lockerz.com invite? message me. |
(#109)
| Member Posts: 50 Join Date: Aug 2009 | ok I got SL on the flash drive, ran netbookbootmaker and popped it in. it ran got to the installer started installing and bingo kernel panic. any ideas? , Snow Leo/Windows 7 ultimateDell Mini 10v - 2 gig ram/120gig hdd/Snow Leo/Looking into a touchscreen mod (still) Dell Mini 9 - 2 gig ram/32 gig STEC/Windows 7 Pro/Snow Leo/Dell 1500 N wireless/what will become of this little lappy....? ![]() |
(#110)
| Junior Member Posts: 3 Join Date: Sep 2009 | Installed 10.6 as instructed...did an upgrade to my 10.5.8. Everything works, including sound! The only issue I am having at all is that it doesn't wake from sleep. I have to hold the power button to do a complete restart. I'm sure this will be sorted out, though. I am running on a mini 10v with bios A05, in case you care. |
| Tags |
| meklort, nbi, nbm, netbookbootmaker, netbookinstaller, official, snow leopard |
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/12338-official-snow-leopard-mini-netbookbootmaker-method-old-method.html | ||||
| NetbookInstaller Update Meklort's Blog | This thread | Pingback | 09-04-2009 04:25 AM | |
| **OFFICIAL** Snow Leopard on the Mini (NetbookBootMaker Method) | This thread | Refback | 09-04-2009 01:17 AM | |
| Forum de la communauté Zimbra francophone / Zimbra Desktop | This thread | Refback | 09-03-2009 05:32 PM | |
| Snow Leopard Pre Order | RK.md | This thread | Refback | 09-03-2009 02:56 AM | |
| cacophony's Bookmarks on Delicious | This thread | Refback | 09-03-2009 02:39 AM | |
| Recent mac Bookmarks on Delicious | This thread | Refback | 09-03-2009 12:38 AM | |
| Lenovo IdeaPad S Series Forum • View topic - Partial Guide to Snow Leopard on S10 | This thread | Refback | 09-02-2009 09:36 PM | |
| Lenovo IdeaPad S Series Forum • View topic - Snow Leopard install on S10 using ext. DVD drive ?? | This thread | Refback | 09-02-2009 11:57 AM | |
