| Junior Member Posts: 7 Join Date: Jun 2009 | ********************************EDIT************** ******************************** This is an old thread, run NBI for the newest Touchpad Driver Hello all, I have a Dell Mini 10v with Mac OS X on it. Much thanks to the Dell EFI crew, (meklort, et al.) I, like many others on the forum have had issues with the trackpad. (which is a nice way of saying it drove me F$#*ing nuts.) Fortunately, I've done some trackpad development before and I decided to hack up the existing trackpad driver. So... I have a trackpad driver that works tons better than the default one and cures the nasty jumpy-ness that drives so many crazy. It's not perfect, and could use some cleanup, but I wanted to offer it to anyone who was interested in trying it. I've sent the source code to meklort and I believe he is planning to incorporate some of the changes into the next release in some form or other, but as this is a major issue for a lot of folks, I figured I'd let the adventurous have a go at it... The patched kext is here: http://ion0.com/hx/ApplePS2Controller.kext.zip Make a backup of your existing one from /Extra/Mini9Ext and place this one in it's place, and then run the UpdateExtra app - Reboot and you should be good. This does assume that you've already installed v18 - so you have the prefpane for tweaking the settings. I'd love to hear how it works for anyone brave enough to try it. JayK |
| Super Moderator Posts: 1,420 Join Date: Mar 2009 Location: United States | Thanks ![]() Will give this a try some time and see how I like it!! Do you mind explaining in a little bit more detail what was changed. This may make people feel more comfortable testing it if they had an explanation of what they are jumping into! Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides |
| Junior Member Posts: 7 Join Date: Jun 2009 | Quote:
Overall, the purpose is to make the pointer behave a little better. I'm sure it could be integrated better but I didn't want to redo more of the driver than I needed to. If you're interested, the actual patch to the existing driver source code is here: http://ion0.com/hx/jayk-TouchPad-Jump-patch.txt If you get the driver from here. mydellmini - Project Hosting on Google Code and apply the patch above, you'll get the kext I shared in my first post. (Note my patch is prepared against rev 135, I haven't tested applying it after the most recent changes. I don't know that it will make a difference, but if you try to apply the patch to the source and it won't work, try pulling revision 135 and trying again.) Good luck! Jay | |
(#4)
| Super Moderator Posts: 1,420 Join Date: Mar 2009 Location: United States | Awesome ![]() Thanks for the info. Did you have any thought about looking into the annoyances regarding the bottom portion of the touchpad where the tactile buttons reside? That seems to be a headache most people have as well. Also, does your driver support side scrolling (vertical) and bottom scrolling (horizontal) or 2 finger scrolling? Just curious! Thanks! Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides |
(#5)
| Senior Member Posts: 127 Join Date: Jun 2009 Location: Texas | I'm definitely going to be trying this out tonight. ![]() |
(#6)
| Super Moderator Posts: 1,420 Join Date: Mar 2009 Location: United States | I am going to move this thread into the OSX Development Subforum. I will change the thread title to reflect the fact that this is for the 10v and will leave a redirect from the current subforum ![]() Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides |
(#7)
![]() I did not change the scrolling code, so the edge scrolling code that was in v18 is what is in here, though it has never worked particularly well for me. I suspect that there is some interaction with the old scrolling code and the new jump-squashing code, but I haven't figured it out yet. I've implemented 2 finger scrolling before on this type of touchpad, but the code is significantly different than the driver I worked on before, and I'm not sure I could implement it without significantly changing a large portion of the driver. I'm willing to take a shot at it, but I know meklort is/was working on that and I don't want to step on his toes. JayK | |
(#8)
| Super Moderator Posts: 1,420 Join Date: Mar 2009 Location: United States | Once again, thanks for the details ![]() I do not think it would be "stepping on his toes" if you both collaborated and came up with a universal solution that would make the trackpad on the 10v the best it possibly can be. I like the direction you are heading in and I know meklort has started doing some development as well. I am not sure the progress meklort has made, since he is probably occupied by Snow Leopard at this point ![]() (which is a good & bad thing) I am really excited to hear about the development being made and will give this a try tonight [as long as I remember!] Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides |
(#9)
| Expert Member Posts: 692 Join Date: Mar 2009 | Since I use my mini9 as a 2nd computer and often just have it with me (although I do have a nice [2 different ones actually] BT mouse for it) the trackpad issue is all that keeps me from replacing it with a 10v. I tried the 10v trackpad at Best Buy and it was awful and that was with the XP drivers made for it. I can only just imagine what its like with the current crop of drivers. You'll be my hero if you can make a usable 10v trackpad. Mini2: Mini9, Black, 2G, 0.3 Webcam, Bluetooth, 32G RunCore, OS X/Win 7, internal PCI-e SHDC Reader Mini3: Mini10v. Black, 2G, Webcam, 640G HD, OS X 10.5.8/Win 7/Ubuntu [Hibernate w/NBI 0.8.3 RC4] Dropbox Referral |
(#10)
| Tags |
| touchpad |
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/12297-better-touchpad-driver-mini-10v-outdated-do-not-use.html | ||||
| How To: Hackintosh a Dell Mini 10v Into the Ultimate Snow Leopard Netbook - Dell mini 10v hackintosh - Gizmodo | This thread | Refback | 10-26-2009 04:21 PM | |
| How To: Hackintosh A Dell Mini 10v Into The Ultimate OS X Netbook | Gizmodo Australia | This thread | Pingback | 10-25-2009 10:14 PM | |
| How To: Hackintosh a Dell Mini 10v Into the Ultimate Snow Leopard Netbook [How To] | KIJO | This thread | Refback | 10-25-2009 06:47 PM | |
| How To: Hackintosh a Dell Mini 10v Into the Ultimate Snow Leopard Netbook [How To]Today’s Review: Latest Technology Review,News And Buying Guide | This thread | Refback | 10-25-2009 06:20 PM | |
| Method 1 - USB Installation via Mac | Guides | OS X | mechdrew | This thread | Refback | 09-02-2009 05:13 AM | |
