(#61)
| Senior Member Posts: 423 Join Date: Sep 2009 | Quote:
NBI 8.2 -> NBI 8.3RC2 -> NBI 8.3RC3 -> NBI 8.3RC5 -> NBI 8.3 alpha USB Legacy Disabled | USB Wake Enabled | BT Enabled | www.suckerpunchent.com | |
(#62)
| Guru Posts: 1,353 Join Date: Feb 2009 Location: Colorado, USA | In terms of kexts, not a whole lot. Under the hood, however, I've added some missing features (that were needed for NetbookCD) as well as bug fixes / more error checking. In terms of future plans, I've added basic device detection support (aka, it'll detect what hardware you have and try to find a suitable kext... kind of like psystars thing, but much better). That means it can determine what bluetooth module you are using and patch the kext with your device id, as well as determine if have supported hardware (say, ethernet) and install the best driver. This way the only use for the machine specific detection is in the case of quirks (and dsdt for now, in the future, that should be generic too). -- Back on topic -- The driver in 0.8.3, while better, still isn't the best. I *will* be working on polishing it up more (smother, less jumps, better three finger swipes, etc). I've started to get annoyed by how it scrolls, so I'll probably be focusing on that (specifically the acceleration as well as how it sometimes reverses directions). Dell Mini 10v | Mac OS X 10.6.5 | 1 GB RAM | 160 GB HDD | BIOS A06 My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a Lockerz.com invite? message me. |
(#63)
(#64)
| Junior Member Posts: 4 Join Date: Oct 2009 | I take back everything bad I said about Gizmodo! I was lucky in that I used 0.8.3 and the new driver so it was easy to fix the problem. The fixed driver radically improves running SL on the mini. It's too bad the timing was slightly off on the article. |
(#65)
| Junior Member Posts: 9 Join Date: Oct 2009 | Inspiring! Thanks for all your hard work! I'm going to make a donation right now! |
(#66)
| Junior Member Posts: 2 Join Date: Nov 2009 | I've been using the trackpad driver from NBI 0.8.3 RC3 on my 10v and OS X 10.6.1. I'm not sure if this is my imagination, but after installing the Secrets pref pane and turning on the "Ignore accidental trackpad input" option (which is not visible in the standard preferences), my trackpad seems much smoother. Better yet, pressing the trackpad buttons with this option on doesn't make the cursor jump around anymore. |
(#67)
| Senior Member Posts: 121 Join Date: Sep 2009 | kappajoe - pls expand a little. Where is this "Secrets pref pane" how do I install it |
(#68)
| Junior Member Posts: 2 Join Date: Nov 2009 | mattchiro: the Secrets pref pane is a small addition to the regular OS X Preferences. It reveals many of the hidden settings in OS X that most users wouldn't know about unless they looked for them through the terminal. Stuff like changing the dock from 3D to 2D, etc. You can download the Secrets pref pane at Secrets. |
(#69)
| Junior Member Posts: 8 Join Date: Oct 2009 Location: Philadelphia, PA | Just a warning about the Secrets pref pane: even with very careful use, I've run into a seemingly unfixable problem (I've even completely wiped out my HDD and re-installed everything, reset my PRAM and NVRAM, etc.) where my boot process is slowed significantly. Secrets has many enjoyable features - but remember: you've been warned! |
(#70)
| Member Posts: 89 Join Date: Nov 2009 | Quote:
sorry, but I call bull**** on this. there's no way secrets pref pane can have such an effect, even after a fresh and clean install. been using this tool for quiet a while now and never had any problems. you must be doing something wrong. | |
| Tags |
| touchpad |
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/12297-better-touchpad-driver-mini-10v-outdated-do-not-use.html | ||||
| How To: Hackintosh a Dell Mini 10v Into the Ultimate Snow Leopard Netbook - Dell mini 10v hackintosh - Gizmodo | This thread | Refback | 10-26-2009 03:21 PM | |
| How To: Hackintosh A Dell Mini 10v Into The Ultimate OS X Netbook | Gizmodo Australia | This thread | Pingback | 10-25-2009 09:14 PM | |
| How To: Hackintosh a Dell Mini 10v Into the Ultimate Snow Leopard Netbook [How To] | KIJO | This thread | Refback | 10-25-2009 05:47 PM | |
| How To: Hackintosh a Dell Mini 10v Into the Ultimate Snow Leopard Netbook [How To]Todays Review: Latest Technology Review,News And Buying Guide | This thread | Refback | 10-25-2009 05:20 PM | |
| Method 1 - USB Installation via Mac | Guides | OS X | mechdrew | This thread | Refback | 09-02-2009 04:13 AM | |
