bmcclure937's Avatar
Default 09-01-2009, 07:01 PM
If you installed OSX 10.5.8 using NetbookInstaller .8.2RC4 then you have the trackpad kext v18 he is speaking of (AFAIK)
Default 09-01-2009, 07:17 PM
I installed this but now it seems like I cannot drag at all while holding the left click button. Also it seems I am able to get it to incorrectly access the new correction code by simply dragging my finger very fast across the trackpad (or at the very least it'll stop dead until i change direction).
I am running netbook installer .8.2 rc4.
Dell mini 10v OSx 10.6.2 | Windows 7
Yuusou's Avatar
Default 09-01-2009, 08:10 PM
Ok I've done a bit of searching and I found the v18 files. I see that there is a v18.2. Is that what's on netbookbootmaker/installer 0.8.2 RC4?
If it's v18, should I replace it with v18.2 and then do the patched ktext in the first page?
Dell Mini 10v A05 N280 2GB 16GB Stock SSD BT Draft N Mac OS 10.6.2
  (#14) Old
Default 09-01-2009, 08:15 PM
Instead of running the patch, he has included the entire kext. You can simply drop that into the Extras folder, remove the old touchpad driver and then run UpdateExtras.app
that is the solution I plan to take when I attempt this tonight
I am hoping reverting back (if needed) will be as simple as rerunning NetbookInstaller to get the 10v kexts back.
  (#15) Old
Yuusou's Avatar
Default 09-01-2009, 09:11 PM
K, thanks for all the help today. You just earned 2 whole internets my friend.
  (#16) Old
Default 09-01-2009, 09:18 PM
No problem man. That is what I am here for, glad I could help you out!
Looking forward to getting home so I can try this out myself
The real thanks should go to the OP for developing this, along with meklort for the development of the original kext!
  (#17) Old
Yuusou's Avatar
Default 09-01-2009, 10:12 PM
True, thanks a lot jayk and meklort for banging out all these awesome updates.
  (#18) Old
meklort's Avatar
Default 09-02-2009, 01:47 AM
All the credit for the fix goes to jayk for this one.
The main reason why this isn't included in NetbookInstaller (at the moment) is it causes a few issues with the touched on the mini 9 (for me at least). I tried to adapt it to wokr on both however I haven't looked at it for a while (preoccupied), so I'll probably include that kext in the next version of NetbookInstaller for the 10v only. I'll still try to integrate it with the mini 9, however if I'm unable to do that I'll just make it detect the 10v and enable the patch automatically.
  (#19) Old
Default 09-02-2009, 02:41 AM
Do not take this the wrong way, I really like the effort that you have put forth to improve the trackpad on the 10v.
After loading your kext, running UpdateExtras and rebooting I took some time to play around with the updated kext. Here are my findings :
1. Side scrolling is practically rendered useless because of the acceleration detection and smoothing functionality that has been added.
2. This also seems to have reduced tracking speed and not allow me to use my trackpad like I am accustomed to. The tracking seems off because when I quickly try to move my cursor the kext detects it and renders my movement as null
3. The kext does improve the tactile button clicking
Overall, I really appreciate the development and the effort but I am reverting back to the standard touchpad kext in .8.2RC4 because normal tracking and trackpad operation is affected to much. I cannot sacrifice that. It seems like the losses outweigh the gains in this so far...
Keep up the work. I am hoping for the best!
  (#20) Old
jcoll81's Avatar
Send a message via ICQ to jcoll81 Send a message via AIM to jcoll81 Send a message via Skype™ to jcoll81
Default 09-02-2009, 02:54 AM
I just installed it and rebooted. I still have some jerkiness, but not as bad as before. It seems to be a step in the right direction but there is still some work to be done. Keep up the good work =)
Dell Mini 10v | 1gb | 120gb HDD | OSX 10.6.2
touchpad
« 1-year NOD32 for Free | Why You don't want to Use Bittorrent »
LinkBack to this Thread: http://www.mydellmini.com/forum/forum-archive/12297-better-touchpad-driver-mini-10v-outdated-do-not-use.html
Posted By For Type Date
How To: Hackintosh a Dell Mini 10v Into the Ultimate Snow Leopard Netbook - Dell mini 10v hackintosh - Gizmodo This thread Refback 10-26-2009 04:21 PM
How To: Hackintosh A Dell Mini 10v Into The Ultimate OS X Netbook | Gizmodo Australia This thread Pingback 10-25-2009 10:14 PM
How To: Hackintosh a Dell Mini 10v Into the Ultimate Snow Leopard Netbook [How To] | KIJO This thread Refback 10-25-2009 06:47 PM
How To: Hackintosh a Dell Mini 10v Into the Ultimate Snow Leopard Netbook [How To]Today’s Review: Latest Technology Review,News And Buying Guide This thread Refback 10-25-2009 06:20 PM
Method 1 - USB Installation via Mac | Guides | OS X | mechdrew This thread Refback 09-02-2009 05:13 AM
