| Member Posts: 30 Join Date: Mar 2009 Location: Tucson, AZ | I was trying to create a complete backup of my entire SSD to an external USB HD. Using some of the instructions in the forums, I was in the command line using the "DD" command. Since the instructions were rather vague on specific syntax, I had to modify it using my (VERY) limited knowledge of the disk/partition/directory structure on my SSD. During the numerous tries typing in the "dd" command, I accidentally reversed the "of" and "if" commands, and this wiped out my MBR. After trying to re-run the DellEFI installer with no success, I conceded I needed to re-install everything from scratch. Not so fast! I first tried to re-install Windows 7 RC-1 using my known-good USB flash-drive installer and its built-in partitioner - FAIL. Then I tried running GPARTED from the bootable USB flash drive I had created - when I tried to delete/resize/erase any of the partitions, it would continuously FAIL. Then I tried running OS-X's Disk Utility from my known-good USB flash drive installer, hoping to use D.U. to re-partition my SSD - FAIL AGAIN. D.U. could not work because it couldn't "unmount" the old OS-X partition. So, I figured the only way I could re-partition/re-format my SSD was to use the original Dell Ubuntu 8.01 "restore" DVD that came with my Mini-9. WRONG!! It runs through the following steps: INSTALL..., found harddisk at /dev/sda... Deleting Partition Table on /dev/sda... Creating New Partition Table on /dev/sda... Formatting /dev/sda2 w/ ext3... Mounting Partitions... Copying system files onto hard disk drive... Copying system ROOT onto hard disk drive... Writing Utility partition to /dev/sda1 Unmounting Partitions... Install sucessfull... Rebooting... During the re-boot process, (did this three times with no success) and on re-start, I get a boot error message: "A disk read error occurred Press Ctrl+Alt+Del to restart" Lastly, I tried to use the Dell Ubuntu "NetBook Remix 9.04" installer, since it re-partitions the drive during install. At the point where it seems to have completed the partitioning process and begins the OS install, I get the following error message: "Input/Output error during read on /dev/sda" (Retry/Ignore/Cancel) (It says this at the step where the dialog box says "Installing System", it gets to 15% and says "Detecting File Systems", and then I get the error message above.) Since SDA is the internal SSD, should I assume my SSD is TOAST? I sure hope there's something besides buying another 64 Gig SSD that I can do.... Please help......... |
| Tags |
| ssd |
