Default Flashing webcam LED on a Vostro A90 - 05-24-2009, 04:55 PM
Hi everyone,
Just installed OSX 10.5.7 on my Vostro A90 via DellEFI. Everything is working really well, except that the little white LED next to the webcam often (most of the time) will start flashing when the system boots or when it wakes from sleep. The only way to get it to stop flashing is to load photo booth or a similar app that accesses the camera, which turns the light solid on, and then close it, which turns the light off. I've done some preliminary searches on the web and on this forum but haven't come up with anything. Any suggestions?
Default 05-30-2009, 07:55 PM
try hitting the number zero sometimes my mini does weird things until i hit that
Default 07-16-2009, 07:10 PM
I too am having the same issue. 90% of the time I startup the A90 or come back from sleep mode, the webcam light will be flashing non-stop until I open up Photo Booth. Vostro A90 here with 10.5.7 installed from the DellEFI method.
Default Flashing (blinking) webcam LED light on dell mini 9 - 07-17-2009, 08:13 PM
I have a dell mini 9 with OS X 10.5.7 and used the EFI 1.2a5 method as well. I have the same issue discussed above regarding a blinking led light next to the webcam at inital boot. I have to open up ichat or photo booth to turn the flashing light off. The flashing only occurs at the initial boot and continues until the webcam is utilized. I seem to recal the flashing occuring with OS X 10.5.6 with the Dellminiboot123 v8.01 as well. Is there a fix for this yet? Thank you so much in advance for anyones assistance...
atm153's Avatar
Send a message via AIM to atm153 Send a message via Skype™ to atm153
Default 07-29-2009, 08:53 PM
What BIOS version(s) are you guys running?
System Specs: "Macbook Mini" Vostro A90, Mac OS X 10.6.3, Stock 16GB SSD, 2GB RAM, 0.3MP Camera, Bluetooth
Software: NetbookInstaller 0.8.4 RC1
Mods: BCM4312 flashed to Airport Extreme, Apple stickers doubled up on the Dell logo, electrical tape over the power light
« need help with os 10.5 install | After install, rebooting into Safe Mode »
