| Member Posts: 91 Join Date: Apr 2009 | This borrows heavily from the following sites:OS X Firewire Mount Point I have an 8Gb Mini which I was finding very tight on space. Having some experience with fstab on linux, I decided to try and mount a SDHC card that I had lying around as part of the file system. This worked out very well for me, and can easily be adapted to mount other parts of the filesystem from SDHC (ie /Applications). I have successfully used this method on Leopard 10.5.6 and Snow Leopard 10.6.2. Notes: #1) After completing these changes you won't be able to swap your SDHC card in and out. It basically becomes a permanent part of your machine. If swapping SDHC cards is important to you, you'll need a external card reader. #2) You need to have basic vi skills to use vifs. There should be lots of guides available if you do a bit of searching with Google. #3) I've also been warned by meklort that the SDHC drivers are buggy. It has worked for me without issue for over 7 months, but your mileage may vary. #4) This guide assumes that you have a HFS (journaled) formatted SDHC card with permissions enabled. The journaling probably isn't necessary (and may even be a bad idea, most similar guides on Linux recommend ext2 over ext3). You can partition and format the SDHC card using diskutil. #5) SDHC cards aren't loaded by default in safe boot, meaning if you follow this guide you won't have access to your profile directory. I was able to login, but couldn't access my downloads directory etc. I have added a new optional step to the guide to make the SDHC required by the OS on safe boot, but I'm leaving this as optional for now. You make the call if you want/need it. Part 1: Enable OSX to Mount your SDHC on Boot (normally OSX only mounts SDHC cards at login) 1. Open the Terminal app and enter the following command: Code: sudo nano /Library/Preferences/SystemConfiguration/autodiskmount.plist Code: <?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>AutomountDisksWithoutUserLogin</key>
<true/>
</dict>
</plist> Part 2: Modify your mount points 1. Insert your SDHC card and then log in to your favorite account to mount the card. 2. Get the UUID of the drive in Terminal ("<MySDHCDrive>" is the name of your SDHC card): Code: diskutil info /Volumes/MySDHCDrive|grep UUID 3. Edit your /etc/fstab file the OS X approved way with vifs (in Terminal): Code: sudo vifs Code: UUID=A740D396-D42D-3348-BD87-709342F87840 /Users hfs rw 1 1 Part 3: Copy the contents from the original /Users folder to the SDHC card 1. Open terminal again and enter the following command: Code: sudo ditto -rsrcFork -V /Users /Volumes/MySDHCDrive Code: sudo mv /Users /Users.orig Code: sudo mkdir -P /Users Code: sudo shutdown -r now Code: cd / sudo df -k Code: sudo rm -dr /Users.orig 1. Edit the Info.plist for the SDHC driver: Code: sudo nano /Extra/Mini9Ext/IOSDHCIBlockDevice.kext/Contents/Info.plist Code: <?xml version="1.0" encoding="UTF-8"?>
<dict>
<key>CFBundleDevelopmentRegion</key>
<string>English</string> Code: <?xml version="1.0" encoding="UTF-8"?>
<dict>
<key>OSBundleRequired</key>
<string>Safe Boot</string>
<string>English</string> Code: sudo kextcache -a i386 -m /Extra/Extensions.mkext /Extra/Mini9Ext/ |
| Junior Member Posts: 26 Join Date: Apr 2009 Location: Newcastle, UK | Would this achieve the same thing a little more easily (for the less geeky amongst us)??? TUAW Tip: Moving your home folder to another disk (or moving it back) You'd still be better getting the disk to mount at boot to make life easier Trust me, I'm a Doctor! Alpine White Mini 9 | OS X 10.5.7 | 16Gb Stock SSD | 2Gb RAM | BT | 1.3 Mp Webcam Will install OS X for beers! Dropbox Invite |
(#4)
| Junior Member Posts: 26 Join Date: Apr 2009 Location: Newcastle, UK | That's what I thought... Might do this as I have very little space left on the SSD and a newly installed 32GB SDHC with nowt on it. + having it mount at boot would be more sensible anyway. Trust me, I'm a Doctor! Alpine White Mini 9 | OS X 10.5.7 | 16Gb Stock SSD | 2Gb RAM | BT | 1.3 Mp Webcam Will install OS X for beers! Dropbox Invite |
(#5)
| Member Posts: 91 Join Date: Apr 2009 | I have a 16Gb. What I did with mine was partition it into 3 areas: Partition 1: 8Gb Fat32 - Storage I may eventually mount this to Downloads or music under my user profile Partition 2: 4Gb HFS mounted to /Users Partition 3: 3Gb HFS mounted to /Applications |
(#6)
| Junior Member Posts: 10 Join Date: Jul 2009 | Thanks for this, worked like a charm. |
(#7)
LinkBack to this Thread: http://www.mydellmini.com/forum/faqs-how-tos/7915-mounting-sdhc-card-users-via-fstab.html | ||||
| Fstab - online discussion summary | BoardReader | This thread | Refback | 06-13-2009 11:21 PM | |
