(#81)
| Member Posts: 46 Join Date: Jul 2009 | i got the alternate broadcom bt module. installed fine. connected blackberry and moto q9c. did the terminal mod and added the extra line thing. and the bluetooth on is still greyed out. plus the sleep function stopped working i redid everything and was about to disable the damn bt from the bios. i deleted the extra iopersonalities edit from above. rechecked and the edit to 688 and 16700 are all still there. i generated and regenerated the adtmt file. trashed the extension.kext file reboot in safe mode. i am now able to reawake from sleep but when I restart, all i get is a black screen forcing me to hold the power button to restart. oh and by the way, i dont see the instructions on backing up the plist file....hell, i can't even locate it outside the terminal. in desperation, i ran fix bt under dellefi 2.5 and did everything all over again and obviously no success what should i do to get this to work? |
(#82)
| Member Posts: 46 Join Date: Jul 2009 | ok, i'm able to restart without the freezing and wake from sleep now but i still cannot turn the bt off. |
(#83)
| Member Posts: 99 Join Date: Mar 2009 Location: Fredericton, New Brunswick, Canada | This worked perfect! My system had the same values as yours so I didn't even need to figure out my DEC values from my HEX values. Thanks! | Dell Mini 10v | Obsidian Black | 1.6GHz | 2GB Kingston HyperX | 1.3MP | 160GB SATA HDD | Bluetooth | 802.11n | Windows 7 Ultimate | Eagles may soar, but weasels don't get sucked into jet engines. - Unknown Before Elvis, there was nothing. - John Lennon |
(#84)
| Junior Member Posts: 25 Join Date: Jul 2009 | Everything was going fine until I tried to search for 33301. Apparently that's missing for me. I wonder what the other potential module numbers might be? |
(#85)
| Senior Member Posts: 371 Join Date: Oct 2008 Location: San Francisco | I did a quick search through the forums and I can't find anyone with my issue. When I pair my iPhone to the Mini 9 with this bluetooth hack it works... once... sometimes. But then I restart the Mini 9 it breaks. When I choose connect from the iPhone the bluetooth icon turns green for a split second and then turns red again on the Mini 9. If I unpair them and repair them it sometimes fixes it but sometimes doesn't and if it does fix it, after the dell restarts it breaks again. Not sure whats going on here. USB Tethering works fine. Mini9 Black/32GB RunCore/1GB/BT/Leopard 2.4GHz Aluminum iMac/320GB/4GB/Leopard 1.83GHz White iMac/150GB/1.5GB/Leopard Server 733MHz PowerMac G4 40GB/512MB/Tiger Server 500MHz PowerBook G3 40GB/1GB/Tiger 25MHz NeXT Cube 750MB/16MB/NeXTSTEP 3.3 |
(#86)
| Member Posts: 62 Join Date: Jun 2009 | Alright, I need some help guys... I, being stupid, ran the script melkort made from page one on my Dell Mini 10v with 10.5.8. It said it worked and reboot to see changes. Upon reboot, it hangs at the Apple logo and spinny thing. I've tried turning off Bluetooth in the BIOS and well as legacy support, even trying to boot into safemode, but no matter what I do it hangs on the Apple logo and the spinny thing. Help! Get yourself a real MacBook with Lockerz! I got invites! PM me. ![]() |
(#87)
| Senior Member Posts: 104 Join Date: Mar 2009 | I attempted to redo this mod on my Dell 9 without success. I upgraded from 10.5.7 where the mod did work, and is unable to get the same thing to work under 10.5.8. One change is that the file that is edited went from 298 lines to 318 lines (I think, it was way more than before.) Anyone have any ides to get this working again? I have a stock Dell bluetooth module, and it was working after the bluetooth mod under 10.5.7 just fine. Thanks. |
(#88)
| Junior Member Posts: 11 Join Date: Jul 2009 | Trying to use an external USB BT module - the IOGear GBU421 micro-sized adapter. I have tried all of the Product ID's I can see in the System Profiler, but none seem to result in correct operation. Below is the whole list that shows up. Any suggestions as to which Product ID to use? Cheers, Lazlo Code: BCM2046B1: Product ID: 0x4500 Vendor ID: 0x0a5c (Broadcom Corp.) Version: 1.00 Speed: Up to 12 Mb/sec Manufacturer: Broadcom Location ID: 0x1d100000 Current Available (mA): 500 Current Required (mA): 94 Composite Device: Product ID: 0x4503 Vendor ID: 0x0a5c (Broadcom Corp.) Version: 1.00 Speed: Up to 12 Mb/sec Location ID: 0x1d120000 Current Available (mA): 132 Current Required (mA): 2 Composite Device: Product ID: 0x4502 Vendor ID: 0x0a5c (Broadcom Corp.) Version: 1.00 Speed: Up to 12 Mb/sec Location ID: 0x1d110000 Current Available (mA): 132 Current Required (mA): 2 BCM92046DG-CL1ROM: Product ID: 0x2148 Vendor ID: 0x0a5c (Broadcom Corp.) Version: 8.18 Serial Number: 000272A1CAF7 Speed: Up to 12 Mb/sec Manufacturer: Broadcom Corp Location ID: 0x1d130000 Current Available (mA): 132 Current Required (mA): 2 BT Terminal Mod w/IOGear GBU421 USB adapter (ProdID 8520, VendID 2652), works, but not entirely meklort's Touchpad drivers VoodooHDA audio and mic All hail Lord meklort - Modder of Kexts, Fixer of Stuff |
(#89)
| Junior Member Posts: 11 Join Date: Jul 2009 | In case anyone cares, I figured out that the correct Product ID to use for the IOGear GBU421 micro BT USB adaptor is the last one - 0x2148 -> 8520. BT Terminal Mod w/IOGear GBU421 USB adapter (ProdID 8520, VendID 2652), works, but not entirely meklort's Touchpad drivers VoodooHDA audio and mic All hail Lord meklort - Modder of Kexts, Fixer of Stuff |
(#90)
| Junior Member Posts: 15 Join Date: Jul 2009 | Offtopic: Does anyone know how I can change the MAC-address of the built-in Bluetooth-module (OS X or WinXP)? Thanks in advance |
