(#11)
| Senior Member Posts: 422 Join Date: Nov 2008 Location: Colorado Springs, CO | Yeah I re-read the howto, and its definitely not what I was thinking when using MBR booting. Sounds like you would definitely need it. Don't blow away your disk. :lol: |
(#12)
| Member Posts: 69 Join Date: Dec 2008 | Cool. I am considering doing this when I get mine. The only reason would be if OS X doesn't boot or something, though. If Parallels is usable on the Mini 9 (anyone know?), should I just stick w/that? I remember reading on here that we need to set the wireless on through XP, and also that XP is necessary to update the BIOS, so I wouldn't want to have to re-install all the time... |
(#13)
| Senior Member Posts: 422 Join Date: Nov 2008 Location: Colorado Springs, CO | Quote:
1. If Parallels is usable on the Mini 9 (anyone know?) - Sure works fine, its slow...what do you expect from this little processor. :lol: 2. I remember reading on here that we need to set the wireless on through XP - No, it was said to turn on bluetooth before you installed OSX. Worst case, you can always just turn it on with a linux live CD if you forgot. 3. XP is necessary to update the BIOS - No, there are a lot of DOS bootable utilities to do it. Search around the forum here, some of the people here have made some very helpful utils that you can use to make a bootable USB stick. | |
(#14)
| Guru Posts: 1,744 Join Date: Sep 2008 Location: Olalla, WA | You do NOT want to update the bios in XP! There are at least 5 people I've seen on this forum that have killed their mini9's doing a bios update in XP. And yes, XP works amazingly well in Parallels. You won't be doing any multimedia with it, or games, but say you need to run Microsoft Money, or something else like that that is windows only. |
(#15)
| Junior Member Posts: 19 Join Date: Dec 2008 | Quote:
(#16)
| Senior Member Posts: 422 Join Date: Nov 2008 Location: Colorado Springs, CO | You can try virtualbox they just updated it a few days ago, works much much better than it used to. Free option if you want to try it. |
(#17)
| Guru Posts: 1,744 Join Date: Sep 2008 Location: Olalla, WA | The SD slot is not USB, so you can't redirect it to the Virtual Machine like you can with most any other USB device. So you won't be able to read SDHC in the SD slot while running XP in a VM anymore than you were able to before. Something worth noting. Parallels version 4 REQUIRES VTx, which is a set of virtualization instructions that Intel came up with, and aren't included in the Atom CPU (and really, most of their CPU's don't have it still). I use Paralllels version 3, works great. |
(#18)
http://www.dosbox.com/ | |
(#19)
(#20)
| Guru Posts: 1,744 Join Date: Sep 2008 Location: Olalla, WA | VirtualBox crashes on me constantly, I've never successfully installed Windows on it. And yes, I'm sure. Par 4 wouldn't even install when it saw I didn't have VTx.. I editted the installer plist to get around that and then the program just flat would not run. Par 3 asks if I'd like to turn on VTx, but will continue to work fine without it. |
LinkBack to this Thread: http://www.mydellmini.com/forum/faqs-how-tos/1634-woooohoooooo-dual-booting-os-x-xp-runcore.html | ||||
| Advanced 2: Multi-Boot Configuration | Guides | OS X | mechdrew | This thread | Refback | 08-19-2009 09:33 AM | |
| Guide Advanced 2: Multi-Boot Configuration | DellEFI | mechdrew | This thread | Refback | 05-29-2009 12:48 PM | |
| Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums | This thread | Refback | 05-22-2009 08:47 PM | |
| Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums | This thread | Refback | 05-22-2009 08:31 PM | |
| Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums | This thread | Refback | 05-22-2009 08:18 PM | |
