(#151)
| Junior Member Posts: 9 Join Date: May 2009 | Is it possible to do this without an external CD/DVD drive? I do have an 8GB USB stick and a 200GB USB HD. |
(#152)
(#153)
| Junior Member Posts: 9 Join Date: May 2009 | Thanks, I got it Now I'm trying to read up on how to dual boot OSX and Win7 with Chameleon, but the info is all over the place regarding the partitions. I already made a backup image of my OSX install already. |
(#154)
| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | As long as OS X is on the 2nd partition, DellEFI should work to get Chameleon going. Not sure if it has to be there, since the Chameleon loader is pretty versatile, but I put it on the second partition just in case. Works like a charm! http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter |
(#155)
| Senior Member Posts: 156 Join Date: Dec 2008 Location: Austin, Texas | I have OS X on my first partition and Windows 7 RC1 on my second and it works fine with Chameleon 2.0rc1. |
(#156)
(#157)
| Expert Member Posts: 692 Join Date: Mar 2009 | Mini2: Mini9, Black, 2G, 0.3 Webcam, Bluetooth, 32G RunCore, OS X/Win 7, internal PCI-e SHDC Reader Mini3: Mini10v. Black, 2G, Webcam, 640G HD, OS X 10.5.8/Win 7/Ubuntu [Hibernate w/NBI 0.8.3 RC4] Dropbox Referral |
(#158)
| Junior Member Posts: 12 Join Date: Feb 2009 | I have followed the guide as closely as possible and have successfully installed XP and OSX 10.5.7. However, neither will boot without using the appropriate boot USB key. Meaning, for Windows to boot, I must use the windows install USB and for OSX, I must use the DellMiniBoot key. When I turn on the mini and it tries to boot from SSD, it reads: boot0: testing boot0: testing boot0: testing boot0: error_ So, my problem is obviously with the boot. I'm just hoping I don't have to reinstall everything again. Also, I'm not sure if the problem is in the order of the partitions, but it is as follows: 1.WNDWS ~20Gb NTFS 2.EFI ~8Mb unformatted 3.OSXMINI9~37Gb HFS+ Suggestions? |
(#159)
| Senior Member Posts: 291 Join Date: Apr 2009 | I've seen that error before but can't remember what caused it. But the more immediate issue is that the OSX partition needs to be partition #2. Try backing up your OSX install, deleting the EFI & OSX partition, and then restoring your OSX install to a new partition. Then rerun DellEFI/NetbookInstaller to reinstall the bootloader. (You can also try just deleting the EFI partition and rerunning DellEFI/NetbookInstaller but I'm not sure if that would work or not.) Triple Boot: Windows 7 | OSX 10.6 | XP |
LinkBack to this Thread: http://www.mydellmini.com/forum/faqs-how-tos/1634-woooohoooooo-dual-booting-os-x-xp-runcore.html | ||||
| Advanced 2: Multi-Boot Configuration | Guides | OS X | mechdrew | This thread | Refback | 08-19-2009 09:33 AM | |
| Guide Advanced 2: Multi-Boot Configuration | DellEFI | mechdrew | This thread | Refback | 05-29-2009 12:48 PM | |
| Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums | This thread | Refback | 05-22-2009 08:47 PM | |
| Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums | This thread | Refback | 05-22-2009 08:31 PM | |
| Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums | This thread | Refback | 05-22-2009 08:18 PM | |
