(#131)
| Junior Member Posts: 7 Join Date: Nov 2008 | mfruit, thanks for the update on how you did your install. I did mine something similar (after reading your post), I had XP already working. I redid the OS X install & ran the DellEFI 1.1 script and . . . it's alive! Thanks to all for their hard work on this! |
(#132)
| Senior Member Posts: 291 Join Date: Apr 2009 | From this message... my-xp-osx-dual-boot-saga,-with-a-happy-ending%C7%83-t7169.html ...it sounds like this thread is very dated now. Highlights: 1. Use DellMiniBoot123 instead of Type11 disc. 2. No need for EFI partition. 3. XP can be installed in partition 1 and OSX in partition 2. 4. Use DellEFI instead of manually copying kexts. Edit: Looks like a custom installer is still needed. Triple Boot: Windows 7 | OSX 10.6 | XP |
(#133)
| Junior Member Posts: 9 Join Date: Apr 2009 | Quote:
thank you for this amazing tutorial, after a few weeks of dual boot failures, I hope this will finally get me going. One silly question, what is "G5"? | |
(#134)
| Senior Member Posts: 291 Join Date: Apr 2009 | Quote:
Hardware: Mini 9 with 32GB SSD. G5 with 10.5.6. USB-DVD. USB-HD. Software: DellMiniBoot123v8.02b1 CD. GParted CD. OSX 10.5.6 Install DVD. XP Install CD. DellEFI 1.1. 1. Create modified OSX MBR Installer. (I used a USB HD & a G5, if you don't have access to a Mac, you have to use the steps outlined in the OP and install OSX twice on the Mini.) 2. Boot from DellMiniBoot123 on the Mini and point to the USB-HD's modified OSX Installer for booting. (You can also just boot from the install DVD but it's faster to use the USB-HD.) 3. Used Disk Utility to wipe SSD and create 2 partitions (partition 1 should be NTFS, partition 2 should be HFS+). Make sure the disk is MBR and not GUID. 4. Boot from XP Install CD and install XP into 1st partition. 5. Boot to make sure that XP loads from the SSD. 6. Boot from DellMiniBoot123 on the Mini and point to the USB-HD's modified OSX Installer for booting. 7. Install OSX on the 2nd partition. It will fail at the end. 8. Boot from GParted and made sure that the 2nd partition is marked "boot". 9. Boot from DellMiniBoot123 and point to the SSD for booting. Give it the "-f" option (not sure if you need this flag). 10. Complete OSX setup and then run DellEFI 1.1 in the default config. Bootloader should install now. 11. Boot to make sure that the bootloader loads and you can boot from either OSX or XP. Look at that other thread for an alternate way of doing the install. This particular way is simply what worked for me given the hardware that I had access to. Triple Boot: Windows 7 | OSX 10.6 | XP | ||
(#135)
| Junior Member Posts: 9 Join Date: Apr 2009 | G5 Power Mac, duh. I knew that was a silly question. This is my first mac in a loooong time, I am not familiar with the product lines. Sorry about that. Could anyone be kind enough to write a step by step tutorial on creating a modified OSX MBR Installer? I have OSX running on my mini now, so I could use that to create the installer on a usb hdd. I also have an external dvd drive, a mac osx dvd, the DellMiniBoot123 cd, gparted (although I'm not 100% sure how to use it correctly), and my dellxp dvd. I think I am ready to go, but creating the process for creating the modified OSX MBR still eludes me just a bit. Thank you guys so much! |
(#136)
| Senior Member Posts: 291 Join Date: Apr 2009 | Since you already have OSX running, you should probably just image your install and then restore it once you've partition your drive. Look at the other dual boot thread for details. my-xp-osx-dual-boot-saga,-with-a-happy-ending%C7%83-t7169.html Otherwise, to create the modified MBR installer, just follow the OP starting here: "Once this is completed eject both the DVD and the USB Key . Then plug the USB key back in (this makes sure it mounts with the right volume name). On your desktop create a new folder and call it OSInstall." Triple Boot: Windows 7 | OSX 10.6 | XP |
(#137)
| Junior Member Posts: 27 Join Date: Mar 2009 | If I already have OS X installed on my mini, is there a method to partition the drive off and install Windows? or would I need to go for a full fresh reinstall? thanks. |
(#138)
| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | Quote:
I did this again last night with Windows 7, all I had to do was set up two partitions with Disk Utility, reformat the first one in Windows 7 and install to it, restore the Mac OS partition to the 2nd partition, and then run DellEFI 1.2 alpha 5, which has it's own dual-boot loader. Flawless! http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter | |
(#139)
| Junior Member Posts: 10 Join Date: May 2009 Location: Boulder, CO | Maybe this is a really dumb question, but after one installs OS X, is there any reason why one couldn't just run Apple's Boot Camp Utility to establish a separate Windows partition and then do the xp installation? Thanks! Mike 17" MacBook Pro Unibody, 2.93 GHz, 4 GB RAM, 500GB 7200 RPM HD, Mac 10.6 Dell Mini 9, 2 GB RAM, 32GB RunCore SSD, Dell 802.11n WiFi, Webcam, Bluetooth. Mac 10.5.8 |
(#140)
I believe it relies on a hybrid GPT/MBR setup that the latest Intel Mac firmware can utilize but the Chameleon bootloader can't. http://refit.sourceforge.net/myths/ Triple Boot: Windows 7 | OSX 10.6 | XP | |
LinkBack to this Thread: http://www.mydellmini.com/forum/faqs-how-tos/1634-woooohoooooo-dual-booting-os-x-xp-runcore.html | ||||
| Advanced 2: Multi-Boot Configuration | Guides | OS X | mechdrew | This thread | Refback | 08-19-2009 09:33 AM | |
| Guide Advanced 2: Multi-Boot Configuration | DellEFI | mechdrew | This thread | Refback | 05-29-2009 12:48 PM | |
| Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums | This thread | Refback | 05-22-2009 08:47 PM | |
| Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums | This thread | Refback | 05-22-2009 08:31 PM | |
| Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums | This thread | Refback | 05-22-2009 08:18 PM | |
