Question Please fix audio after sleep - 08-23-2009, 08:54 PM
I've used this forum to get everything running on 10.5.7 along with steps to get audio working. However the one thing I still can't get to work is the audio functioning after sleep. If I reboot it's fine again, but coming out of sleep cripples it.
I've tried applying the VerbHelper.kext as mentioned in this thread:
Building 100% Vanilla on 10v (starting with fully working Audio)
But it still doesn't work. I am running 10.5.7 on a mini 10v that was initially installed with 10.5.6 using the DellEFI method and then incrementally updated.
If anyone's got a simple documented fix for this I'd be really grateful. Also, what's the easiest way to check what version of a kext you're using?
Cheers,
sc
« 10.5.8 is out.... how to upgrade | help my mac osx crashed after update »
