| Junior Member Posts: 11 Join Date: Jul 2009 | A friend bought a dell mini 9 in Japan (because he lives in Japan). Osx was already installed but to save space, the seller had only japanese installed. Is there a way to "add" a language to osx without having to reinstall everything? Thank you |
| Guru Posts: 1,375 Join Date: Mar 2009 Location: Texas | According to the Apple website, you need to do a custom install and select the language you want to install. Mac OS 9: How to Install and Remove Languages 10V | OS X 10.6.7 | NBI 20100616212351 |BIOS 06|160 GB|1 GIG RAM| 6 Cell Dell Battery Functioning Hibernation Back up Mini 9| OS X 10.6.7| NBI 20100616212351| BIOS 05 | 32 GB SuperTalent | 2 GIGS RAM |
| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | You should be able to access the Optional Installs folder of the Mac OS X Install DVD and there will be a package in there. Open it, and you will hopefully have the option to install other languages that are included on the disc. http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter |
(#4)
| Junior Member Posts: 11 Join Date: Jul 2009 | Thank you I forwarded your answer to my friend. I hope it works |
« Any recommendations for improving battery life?
Virtually increase your Dell Mini Screen Resolution »
