| Junior Member Posts: 27 Join Date: Aug 2009 | Been waiting for Safe Sleep/Hibernate on your Mini? Well here you go. I got it working on my 10v with 10.5.7 (DellEFI - though this shouldn't matter much). Safe sleep saves the contents of your RAM to an image on the hard drive whenever you put the device to sleep. After getting it set up, you'll be able to, just like on a real Mac, not worry about your battery dying while it is in sleep mode. If it dies, it will restore back to how it was once you power up again. To get going, you'll need Chameleon 2.0 RC2 r640. Download this and extract it someplace. We'll come back to this later. Modified boot file, attached to this post. Extract this someplace as well. Next, make sure secure virtual memory is turned off. It is under Security in System Preferences. Now, if you disabled hibernate before, run DellEFI. Do a custom install, the only thing you have to do here is re-enable hibernate (ignore the not recommended warning - it actually works with the new loader). Now, we'll install the loader. Fire up Terminal and change into the i386 directory (within the Chameleon directory from the file you extracted). For example, if extracted in the Downloads folder, it would be cd ~/Downloads/Chameleon-2.0-RC2-r640-bin/i386. Then run the following three commands: sudo fdisk -f boot0 -u -y /dev/rdisk0 sudo dd if=boot1h of=/dev/rdisk0s2 [note, this line may be different. If you're not sure, go to Disk Utility, right click your main partition and hit information, replace the 2 with whatever the partition # is.). Now, change into the directory where you extracted boot.zip. Then run: sudo cp boot / [note, if you have an EFI partition, copy the boot file there instead] At this point, you have the new version of Chameleon. Take this opportunity to reboot, you should reboot just fine (it may hang on a screen with text about a hibernation file, if so, wait a few seconds and it should continue). Once you're back up and running, you can test it out. I'd recommend deleting your hibernation file, just to make sure there's nothing stray. To do that, just run `sudo rm /var/vm/sleepimage` in a terminal. When you put the machine to sleep, it will take a few extra seconds to write the image to disk before the power light goes from solid to pulsing. This is normal. The more ram you have, and the more stuff you have open, the longer it will take to write. To test its functionality, wait until the light is pulsing, and pop your battery and unplug it from AC to kill it. Then power it back up. You should see a screen with a faded out screenshot of what was on your screen before as it restores, and you'll be back how it was before sleeping. This was only tested with 10.5.7 (via DellEFI) on a 10v, but should work for anyone who uses Chameleon, albeit maybe with a few mods. |
| Senior Member Posts: 119 Join Date: May 2009 Location: Lincoln, NE | Interesting, but it didn't seem to work on 10.5.8. Followed your guide to the letter. Software: NetbookInstaller 0.8.4 RC1 Mods: BCM4312 flashed to Airport Extreme, Apple stickers doubled up on the Dell logo, electrical tape over the power light |
| Member Posts: 53 Join Date: Jun 2009 | atm153, in another thread you mentioned that you got this working. Care for a blow by blow guide for 10.5.8 on the Mini 9/Vostro? |
(#4)
| Junior Member Posts: 27 Join Date: Aug 2009 | Whoops, I didn't realize you needed the modified boot file I have. I fixed the instructions. For you, download the attached zip file, extract it, and do the sudo cp boot /, and reboot. |
(#5)
| Member Posts: 67 Join Date: Jun 2009 Location: Raleigh, NC | I don't see the zip file, am i missing something? http://osx.mechdrew.com/ |
(#6)
| Junior Member Posts: 27 Join Date: Aug 2009 | Man, I'm not doing so great. :P Forgot to click upload. It's there now though. |
(#7)
| Member Posts: 67 Join Date: Jun 2009 Location: Raleigh, NC | That seemed to do it! Since i had already installed the new chameleon bootloader I followed everything but that part. I opened some apps, put my 10v to sleep, pulled the battery and restarted and when it rebooted it showed the grey screen and progress bar just like my Macbook Pro. Nice work, thanks for the help! http://osx.mechdrew.com/ |
(#8)
| Member Posts: 53 Join Date: Jun 2009 | Followed your instructions exactly, but I'm getting a "Hibernate image is too old by XXX seconds" error on booting in 10.5.8 on a Mini 9. I have a new sleepimage file, but it isn't modified when I put it to sleep and wake. Gathering that this is the kind of message people were getting when enabling hibernation on old versions of Chameleon, I guess it's not working at all for me. ![]() |
(#9)
| Senior Member Posts: 119 Join Date: May 2009 Location: Lincoln, NE | Software: NetbookInstaller 0.8.4 RC1 Mods: BCM4312 flashed to Airport Extreme, Apple stickers doubled up on the Dell logo, electrical tape over the power light |
(#10)
| Junior Member Posts: 27 Join Date: Aug 2009 | I upgraded to 10.5.8, I've restored my 10.5.7 image, due to random crap not working (like the battery/AC profiles, battery time remaining, etc). I never did see if hibernate worked on it, though. |
