Switters's Avatar
Default Slow WiFi on Mini10v - 07-31-2009, 05:13 PM
Hi
I´ve installed OS X 10.5.7 on my Mini10v and everything is working fine.
Except the WiFi. It´s very slow (3-4 KByte/sec)!!!
Any Idea what´s wrong here ??
thnx
Switters
CyG CyG is offline
Default 07-31-2009, 06:05 PM
It will easier to solve your problem after you've answered some questions. What networks have you tried? Are you sure those networks are working optimally? Did you install OS X using a method preferred by this forum and tried reinstalling kernel extensions?
Switters's Avatar
Default 07-31-2009, 06:12 PM
It´s my lokal Wifi and with my iMac it´s fast.
I´ve used this method
Kernel Extensions? Never heard about... :-/ )
CyG CyG is offline
Default 07-31-2009, 06:44 PM
Run the NetbookInstaller one more time. It often helps work out kinks.
Slow connectivity is very suspicious. Are you sure your wireless bandwidth isn't being choked up by something else?
« After install, rebooting into Safe Mode | Could someone make a sticky of all the space saving techniques for osx? »
