| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | As reported by DownloadSquad, Silverlight 3 is now out. You won't find it officially on the Silverlight site, but you can download it here. You will need to modify the installer package in order for it to install, otherwise you will get the infamous, "Silverlight 2 may not be installed on PowerPC." error. (Yes, Silverlight 3 still says "Silverlight 2" in the error message. It's still version 3.) I have copied my old set of instructions from http://www.mydellmini.com/forum/mac-...ac-solved.html so that everyone can make the necessary adjustments. Quote:
http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter | |
| Junior Member Posts: 19 Join Date: Jun 2009 | Supposedly 3.0 is supposed to offload some processing to the GPU, but if there are any performance gains I don't see them at all. Netflix is still as choppy as before. ![]() |
| Member Posts: 87 Join Date: Jan 2009 | Netflix is sometimes choppy for me too but I find that using a notebook cooler helps a bit. Not sure if I'm just imagining things but cooling it down seems to help. |
(#4)
| Super Moderator Posts: 1,356 Join Date: Jan 2009 Location: Idaho | Oddly enough, I have slightly improved performance in windowed mode with Netflix, but fullscreen looks worse in my opinion. Then again, I am using Firefox, maybe I should try Safari. http://osx.mechdrew.com - News and Guides for Installing Mac OS X via NetbookInstaller - Now on Twitter |
(#5)
| Junior Member Posts: 2 Join Date: Aug 2009 Location: Pittsburgh, Pennsylvania, USA | Quote:
(#6)
| Super Moderator Posts: 1,420 Join Date: Mar 2009 Location: United States | Awesome news mechdrew And great post layout and organization, as always.Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides |
LinkBack to this Thread: http://www.mydellmini.com/forum/faqs-how-tos/10325-silverlight-3-0-works-same-fix-2-0-a.html | ||||
| netputing.com • View topic - NetbookInstaller 0.8.2 Release Candidate | This thread | Refback | 08-26-2009 10:22 PM | |
