polar polar is offline
Default Car power adapter for the Mini 9 - 11-15-2008, 06:45 PM
Does anyone know if you can obtain a Car Lighter Socker power adapter for the Mini 9
Dell Mini 9: Black, WinXP, 1GB RAM, 8GB SSD, Vodafone 3G Built in (This is cool). 250GB USB HDD, 4GB SD Card. ITunes, Office 2007, Blackberry Desktop software.
jason.sgtski jason.sgtski is offline
Default Re: Car power adapter for the Mini 9 - 11-15-2008, 06:58 PM
White mini 9 with 8g ssd, BT, 1g ram, 1.3 m pixel cam, ubuntu 8.10.
mostlyharmless22 mostlyharmless22 is offline
Default Re: Car power adapter for the Mini 9 - 11-15-2008, 07:21 PM
Originally Posted by jason.sgtski
http://www.radioshack.com/product/index.jsp?productId=2194429 that should do fine.
Did you read the reviews on this thing? One says it blew out his laptop charger. I would never buy this. I think I'll wait for OEM.
ken_r ken_r is offline
Default Re: Car power adapter for the Mini 9 - 11-15-2008, 11:34 PM
http://www.igo.com/category_adapter.asp
I ran this thread for the mini 9 somewhere on the board. Several people suggested that I just use a cheep inverter. I always thought that unless the inverter is pretty good and a sine wave it was not safe for a computer or delicate piece of equipment. This usually spells expensive.
Igo has three. I think that for many different inspirons the connectors are the same. This is made for computers and also they have tips to charge my other computers and some of my other electronics.
This is the way i intend to go.
ken r
Stories by Ken
DragonRider DragonRider is offline
Default Re: Car power adapter for the Mini 9 - 11-16-2008, 07:35 PM
Let us know how the Igo goes... I tried emailing them to ask what adapter would work. My only concern is I have a 90 watt Igo and I don't want to give it too much juice.
Default Re: Car power adapter for the Mini 9 - 11-17-2008, 07:04 AM
go to the Igo site. they now have listed the correct adapter tip.
I am sure some other companies like Targus will soon list the Mini 9
ken r
Stories by Ken
Carlo Rossi Carlo Rossi is offline
Default Re: Car power adapter for the Mini 9 - 12-06-2008, 10:43 AM
My friend worked for radio shack for years, the igo blew up many of computers, use at your own risk.
dayene dayene is offline
Send a message via ICQ to dayene Send a message via AIM to dayene Send a message via MSN to dayene Send a message via Yahoo to dayene
Default Re: Car power adapter for the Mini 9 - 12-06-2008, 02:05 PM
i used this on my laptop and the charger started smoking. i was able to pull the cord out quick and laptop is fine.
http://www.dayene00.blogspot.com
http://www.dayene-photos.blogspot.com
http://www.dayene-iphonetography.blogspot.com
Dell Mini 9 => White, Windows Ulitimate, 16GB SSD, G. Skill 2GB RAM, 1.3MP webcam.
trackknife trackknife is offline
Default Re: Car power adapter for the Mini 9 - 01-02-2009, 10:55 PM
I have a 70w Targus AC/DC power adapter with multiple tips for different laptops and such. Looks like tip # 3 and tip #4 seem to fit the socket, but I know this thing only wants 30-40 watts ... anybody tried this yet?
Dr Some-what Evil's Avatar
Default Re: Car power adapter for the Mini 9 - 01-08-2009, 12:42 AM
I found that a standard adapter to plug your 110-120 volt whatever into works best and can be used with a number of different items. I used this same adapter to power a small desktop fan while my truck was parked. Sure helped beat the summer heat and it never blew a fuse on itself or the truck. With proper installation you can have 2500-3500 watts available but I only needed 75 watts so i got a inverter to handle twice that so it would be safe.
Just my Two Cents on the issue.
Mini-9
STEC 8 gig SSD
RAM 2Gig 800Mhz.
WWAN parts in place
« Leopard, USBModem, Sprint, Palm 755p tether | Adapter to use old Dell D600 laptop DVD drive on 10V? »
