eXplicit's Avatar
Send a message via AIM to eXplicit
Default Car charger? - 11-13-2008, 06:57 PM
Is there one?
Default Re: Car charger? - 11-13-2008, 07:01 PM
well i don't know if they make a specific car charger but I have something similar to one of these.
http://www.newegg.com/Product/Product.a ... 6842121019
If the rule you followed brought you to this, of what use was the rule?
Default Re: Car charger? - 11-15-2008, 11:47 PM
Try Igo. they make three different car chargers.
ken r
Stories by Ken
Default Re: Car charger? - 11-24-2008, 02:47 PM
Another option would be to use a universal laptop adapter. I found one on ebay that lists the mini 9 compatibility information, and was reasonably priced. Power inverters are handy, but why step up to 120v from 12v then step down to 19v?
Default Re: Car charger? - 11-25-2008, 05:24 PM
I bought a 400w inverter from target (http://www.invertersrus.com/pi400ab.html) and a sony fm transmitter which allowed me to power the dell mini the entire 1200 mile trip from Massachussetts to Tennessee and play it over the car stereo. I also used my old 80gb Ipod in disk mode and filled it with movies. Was a lifesaver with kids in the car and worked perfectly!
Default Re: Car charger? - 11-25-2008, 06:19 PM
Why did you need 400w? Wouldn't the 100w have done the same thing? Or did you have to power the Ipod as well?
Default Re: Car charger? - 11-25-2008, 06:50 PM
I chose that one as it had 2 plug sockets and a usb plugin, so we could use the laptop, charge my phone and charge the kids psp/ds at the same time. I also liked it as it had a built in cooling fan and auto cutoff if it overheated.
Default Re: Car charger? - 11-28-2008, 02:49 AM
I have a 4kw inverter in my work van, but still prefer a charger that goes into the cigarette lighter and converts straight from 12v to 19v.
Default Re: Car charger? - 02-25-2009, 03:44 AM
Would a car charger work also with a 12 V boat battery (sail boat) where the voltage might fluctuates between 12 V and 15 V, the battery being charged by a solar panel?
Or do I need to get something special that would stabilize the input voltage?
Default Re: Car charger? - 02-26-2009, 04:36 PM
Cool plan. I'm probably going to do something similar on the next road trip -- but how did you cope with an FM transmitter? The last time I tried that, driving from Indiana to Tennessee, we gave up and bought a tape adapter. There were simply too much interference from local radio stations, especially in Illinois.
« Help! Need custom skin for mini9 | External HDD »
